| Dookie |
| Posted: Nov 17 2002, 04:44 PM |
I have a little prob. i donnow but Ive never paid attention to that issue.
When Im done with a video encoding , and I Start Watching It, I cant scrool the time scroller , that mean that I can only watch the movie from the beginning, what option i missed up ?!.
please help me 10quol. [B] |
| jcsston |
| Posted: Nov 17 2002, 06:55 PM |
Matroska Dev
What program are you using to watch it? In Virtualdub you have to stop playing it before you can seek around.
| Dookie |
Posted: Nov 19 2002, 03:54 PM |
Im using both : DivX Player 2.0 Alpha and Windows Media Player 9
i dont think that the player is the problem,i guess its something in the encoding process.
| Morsa |
| Posted: Nov 19 2002, 11:14 PM |
try installing ffdshow . It is a directshow filter that supports Divx, Xvid, etc. |
| Dookie |
Posted: Nov 21 2002, 02:11 PM |
10x I try that ,didnt work out.
maybe its not a video problem , maybe the memory or the video card.
I have many divx videos that have the same problem, but also many videos without that problem... |
| Dookie |
Posted: Nov 21 2002, 04:37 PM |
Hey. sometimes when I openning a video file i see a window telling me about a low virtual mememory, and its says that some applications may be denied!.
i have 192MB RAM and 1.5 Giga free on drive C. |
| MPAAdefector |
| Posted: Nov 21 2002, 05:30 PM |
What codec are you encoding your file with?
When you open your file in Virtualdub, in the "Open Video File" window, check the "Popup extented open options". Choose your file, clieck Open and in the new window that will appear, check "re-derive keyframe flags and click OK.
Encode a small portion of your movie to test. Open that test movie in your player and verify that you can scroll in it. If it work, then I guess you can go ahead and encode the entire file. If it does not work... ahem, what codec are you encoding your file with? |
