Cannot Open Avi In Virtualdub, Avi Import filter error: bad format
Genasor
Posted: Oct 18 2002, 11:09 PM
I've used Flycap v2.5.2 to record a video of a about 1 hour (8.12GB). Unfortunately, I cannot open de avi file!
VirtualDub gives this error:
"Cannot determine file type"
And as avi compatibility mode:
"Avi Import filter error: bad format (80044066)"
Is my file lost? isn't there a way to at least extract the audio track? At worst is it conceivable to edit and change some headers ?
Thanks for your help
ChristianHJW
Posted: Oct 19 2002, 09:18 AM
Does the AVI play in Mediaplayer ? If so you can try AVISynth and its 'DirectShowSouce' command to frameserve it to Vdub and make a valid AVI from it ...
Neo Neko
Posted: Oct 19 2002, 10:34 AM
VirtualdubMod Alpha tester
Seems I remember hearing bad things about flycap somewhere. Don't ask me where though. I agree with Christian here just a slight alteration. With AVISynth 2.06 you should try the avisource option. It should pick up both the video and audio. Unless there is a newer version of AVISynth that can pick up the audio via Directshowsource.
Genasor
Posted: Oct 28 2002, 08:50 PM
Thank you for your reply, and sorry to answer that late.
I've tried the avisynth solution (that's a really cool piece of soft btw), but to no avail sad.gif , tried other stuff claiming to open any avi, even broken, but they all failed.
So, since the audio was pcm, I renamed the file to wav and openned it in a wav editor. There I found the audio chunks.
So now I'll tackle the writting of a prog that gathers all these chunks...
many thanks
3 replies since Oct 18 2002, 11:09 PM Track this topic | Email this topic | Print this topic
