Editing Dv Avi Files, can Vdub do it?
larrylynch3rd
Posted: Sep 25 2002, 02:15 PM
I have been using Virtual dub for a long time, and haven't had any problems up 'till now.
I recently aquired a Digital Cam-Corder and have been doing some video work with it.
First time I needed to edit out a few seconds of video from the middle of a captured file I of course tried to do it with Virtual Dub.
Virtual Dub cant load the file because its not "VFW" compatible. What do I need to do to make the file "VFW" compatible, so I can edit it with my favorite editing program????
AFAIK NONE of the software I have paid good money for (Video Studio 5.0 ect) can do anything but trim the beginning or end of a file, they cannot remove frames or sequences of frames the way Vdub can.
Forgot to mention:
OS= Windows 2k sp3
System=1.2 gig Athlon & 1.2 gig Pentium both with 160 gig 7500 rpm drives and 512 meg pc133 ram.
Larry Lynch
Mystic, CT
Neo Neko
Posted: Sep 26 2002, 08:55 AM
VirtualdubMod Alpha tester
Use Avisynth with Virtualdub and your worries are over. www.avisynth.org has the version you need. Once you download and run the install.reg simply create a file with a *.avs extension. Inside that file all you need is one line.
avisource("my.avi")
Open the *.avs file in Virtualdub and compress to your hearts content. You can even do video processing such as deinterlace or cleanup with AVISYNTH.
kmlo
Posted: Nov 5 2002, 08:43 AM
Hi
i just post about DV codec, once you have DV codec installed,everythign is OK.
if ur rich, pay $50 for mainconcept, if not, try demo or get panasonic. matrox.
i seldom use avisyth. so i rather solve it with a DV codec.
pls search in this forum. about my posting.
kmlo
larrylynch3rd
Posted: Nov 11 2002, 12:08 PM
QUOTE (kmlo @ Nov 5 2002, 02:43 AM)
Hi
kmlo
Since Im doing the capturing and the rendering (and playing the avi files between steps) on this computer, I'de have thought the codec was here..
3 replies since Sep 25 2002, 02:15 PM Track this topic | Email this topic | Print this topic
