Know How To Use Jobs?
Morsa
Posted: Sep 21 2002, 12:44 AM
Well, that's my problem now.
I don't really don't know how to make a job list and I can't get any information!!!!!
Need good help with very detailed information, examples included if posible.
Posted: Sep 21 2002, 05:02 AM
After loading your video(s) and configuring your filters and compressors, the final act in any VirtualDub session is to save your new AVI. However, instead of saving it you can check the "Add operation to job list and defer processing" box. This postpones the processing until such time as you are ready. You can even exit VirtualDub and come back days later and the job will still be waiting for you to tell it to start. Multiple jobs may be prepared and deferred to the job list. To see your current job list, choose File->Job control.
Morsa
Posted: Oct 12 2002, 11:10 PM
Thanks in advance.
Now that I know how to use jobs, I need to know if there is any way to make the same things but with image sequences instead.
Posted: Oct 13 2002, 03:47 AM
sad.gif Nope. The "Save image sequence" menu doesn't give any option to add its operation to your jobs list.
Posted: Oct 13 2002, 08:57 PM
Image sequence saves will be batchable in 1.4.11.
Kippesoep
Posted: Oct 13 2002, 09:19 PM
And "Save to Wav"? I have to use that feature a lot because of the opendml header problem present in 1.4.10.
Morsa
Thanks Avery!!
Release 1.4.11 would be within this year?????
sbrewer
  Posted: Nov 7 2002, 12:06 AM
Can I add a capture job?
Schedule a capture to start and stop at a specified time?
Morsa
Posted: Nov 7 2002, 01:42 AM
doesn't VirtualdubVCR mod have this feature?
Did you try it?
BaronVlad
Posted: Nov 15 2002, 07:12 PM
Terrorhörnchen
QUOTE (Morsa @ Nov 6 2002, 07:42 PM)
Did you try it?
Works
Hochachtungsvoll
BaronVlad
9 replies since Sep 21 2002, 12:44 AM Track this topic | Email this topic | Print this topic
