| Brassplyer |
| Posted: Oct 25 2012, 01:13 AM |
Using the resize filter, when would you use the option for codec friendly sizing - multiples of 2, 4, 8, 16?
Thanks |
| Posted: Oct 25 2012, 05:20 AM |
It's more of a safety feature than anything else A lot of codecs require that the size of videos are multiples of 2, 4, 8 or 16 Also, certain codecs can be more efficient if the sizes are multiples of 8 or 16
You can waste a lot of time if the codec lets you pick a width that won't actually playback properly XVID encoded videos with an odd width can play back as a slated black and white mess But that all depends on exactly what codec is decoding the video
Safest choice is 16, but 8 and 4 are usually fine At minimum, pick 2 as hardly anything works with odd widths
| Posted: Oct 28 2012, 07:56 PM |
More applicable is that there are some codecs that simply won't even allow compression and will throw errors if you don't adjust to an appropriate width and height. The adjustment options save you the trouble of setting a percentage, reading off the sizes, and then manually adjusting both the size and cropping options to make the sizes work out without distorting the aspect ratio. |
