| aodhanloki |
Posted: Oct 11 2012, 10:58 PM |
Thanks in advance for your advice;
I'm new to video editing and I am trying to make a video about 10 minutes long with 20 - 25 different "scenes". I've taken a 15 minute long video that I took with a point and shoot camera and sliced it up into the different scenes that I want and created separate avi's for each. I am also taking video that I have had on my computer some time which has been taken with different cameras (some from camcorders, some from other point and shoot cameras) and I have sliced that up into different scenes and created separate avi's for those.
In the end, I have 20 - 25 different AVI's that have varying properties. Here's what I've done so far:
1) Error: Video size doesn't match Solution: Easy - resized video so they match
2) Error: Frame Rate doesn't match Solution: Obvious - select full processing and change frame rates to 30fps
3) Error: Sample Rate doesn't match Solution: Select full processing on audio and change sample rate to 48000hz for everything
4) Error: Sample Size doesn't match Solution:
This is where I'm at. Besides the fact that I feel like there are way too many steps to make these compatible, I still don't know if I'm de-syncing the audio and causing other problems that I'll find when I finally get these two things to combine. And I'm just on the first two scenes!
Can anyone else help me out with a better solution/best practice for this kind of thing?
Thanks again for any help you can provide!
-Matt |
| -vdub- |
| Posted: Oct 13 2012, 01:28 AM |
Joining video clips
Get information from each video using MediaInfo, GSpot or Virtualdub. (MediaInfo preferred atm)
Video Video Framerate (fps) Aspect Ratio (16:9 etc) Frame Size (width:height)
Audio Sample Rate (KHz) Bitrate (kbps) Audio Framerate (fps) [see below - Audio Other]
Video Other Video source Progressive or Interlace Video destination Progressive or Interlace
Audio Other Audio (fps) Audio has framerate (fps) also and will be the same as the video. When change the video (fps) also need to change the audio (fps). To keep the audio aligned (sync and duration) to the video as it was originally. MediaInfo can show both the video and audio fps (if known by MediaInfo).
Changing audio frame rate using external audio editor Load audio into an external audio editor, set/change the fps to what you need. Export the audio to desired format add to video in virtualdub using Audio - Audio From Other File...
Changing audio frame rate using Virtualdub Time Stretch audio filter Full Audio Processing - Use advanced Filtering - Filters - [Add (in order)] Input - Time Stretch - Output This will ensure if any of the video have different fps will stretch to new fps if changed.
Notes Video Other not needed to join video clips, although can keep the video quality with each joined video clip. Audio Other not needed to join video+audio clips. Although can keep the audio sync and duration correct to each joined video clip. |
| websmrf |
| Posted: Oct 25 2012, 12:05 PM |
I don't remember having seen the "Sample Size doesn't match" error before, but you could go through an AVISynth script which might report the difference between clip's characteristics in a more detailed way.
Otherwise go to virtualdub's File -> File information menu for two of your different clips which won't join, and post the screenshots here.
w. |
| Posted: Oct 25 2012, 12:29 PM |
Sample size not matching is when one clip has 16 bit audio and the other has 8 bit In the audio conversion page just change the sample size to 16 bit, just like you do for changing the rate to 48000
