| pam |
| Posted: Oct 3 2012, 10:14 AM |
Hi, can compress Mp4 video using VDub. Anybody can help or point me to earlier post ? Much appreciated |
| Abrazo |
| Posted: Oct 3 2012, 07:34 PM |
- if you ask : Can I "open" MP4 with VirtualDub ... Yes you can, when you install the QuickTime-plugin for VirtualDub http://home.comcast.net/~fcchandler/index.html (actually this site is not available)
- if you ask : Can I "save" to MP4 with VirtualDub ... Yes you can, when you do use external encoders: http://forums.virtualdub.org/index.php?act...=ST&f=3&t=18840 |
| pam |
| Posted: Oct 4 2012, 03:57 AM |
Thanks any idea where can get fcchandler |
| malky |
| Posted: Oct 4 2012, 10:22 AM |
Seems to be off the air. Here's another link.
http://www.videoaudio.pl/infusions/pro_dow...oad.php?did=359 |
| pam |
| Posted: Oct 9 2012, 08:21 AM |
Thanks have downloaded the plugin but whenI open MP4 video it has "missing codec AVC1" |
| Placio74 |
| Posted: Oct 9 2012, 09:44 AM |
VideoAudio
You need appropriate VfW codec - for MPEG-4 AVC install ffdshow VfW. Go to ffdshow video encoder configuration and set (in decoder) tab support for H.264/AVC. Or You can try x264vfw.
| Abrazo |
| Posted: Oct 9 2012, 08:17 PM |
Thanks malky and Placio74 for the extra information. Myself I was not aware of the fact that the QuickTime plugin seems to work like a splitter and that it needs extra decoders for video and audio...
Decoders for the video:
- ffdshow: http://sourceforge.net/projects/ffdshow-tryout/files/
- x264vfw: http://sourceforge.net/projects/x264vfw/files/
Decoder for the audio:
- aac acm: http://www.videoaudio.pl/infusions/pro_dow...oad.php?did=341
N.B.: fccHandler's homepage (VirtualDub plug-ins and acm codecs) is still not available: - http://home.comcast.net/~fcchandler/index.html |
| pam |
| Posted: Oct 10 2012, 10:53 AM |
Have install ffdshow and x264vfw. Cannot load MP4 to VDub- it say no audio decompressor could be found. Help please |
| Abrazo |
| Posted: Oct 10 2012, 05:09 PM |
Dear pam, did you read my answer (here above) completely ?
You say you installed ffdshow and x264vfw, but probably not the aac acm !
The first two are "video" decoders, the last one (the acm) is an "audio" decoder.
Take care to install the xx-bit version (32 or 64) of the acm that corresponds to the xx-bit version of VirtualDub that you have installed. |
| pam |
| Posted: Oct 11 2012, 11:15 AM |
Thanks for the reply. Yes have also aac acm (32)
Both ffdshow and x264vfw were downloaded to my c:/program while aac acm (32) were extracted to Vdub/plugins.
Did I do the right thing?
| Placio74 |
| Posted: Oct 11 2012, 01:42 PM |
VideoAudio
| QUOTE (pam @ Oct 11 2012, 01:15 PM) | | Both ffdshow and x264vfw were downloaded to my c:/program ... |
It does not matter where You downloaded - just install.
| QUOTE (pam @ Oct 11 2012, 01:15 PM) | | ...while aac acm (32) were extracted to Vdub/plugins. |
This is not a plugin. Again, it does not matter where You extract downloaded archive - just install. However, in this case by old-fashioned way - click right mouse button on .inf file and choose Install option from context menu. Or (especially if you have a 64-bit system) run "Install the 32-bit codec.bat" file
