| evropej |
| Posted: Aug 18 2011, 03:11 AM |
Any suggestions? I tried smart filter and I have pretty good results but I am thinking I missing something. Also, how are the field and frames handled? What are some good suggestions on filters and settings.
Any advise would be appreciated. |
| Posted: Aug 23 2011, 05:45 AM |
I think you'll need to provide more information about what you're trying to do. For one thing, it matters whether you're trying to target a progressive or interlaced output -- if your output is going to be interlaced as well then you'll want to avoid deinterlacing if possible. Also, some operations can be done prior to interlacing, like levels adjustments, whereas other operations like resize/resample really need to be done on deinterlaced video. |
| erudub |
| Posted: Aug 25 2011, 05:04 AM |
I am using TDeint (AVISynth) and the result is crisp!
Only problem: during movement the smearing seems to be lacking a bit, so the single pictures are "hopping" once in a while. Perhaps the settings/algorithm is too crisp?
Greetings, E. |
| evropej |
| Posted: Aug 25 2011, 12:36 PM |
My output target is a progressive file which I will post process again. I am getting decent results with my current process but I am not completely satisfied, the edges are a bit blocky. Deinterlacing on another program also gives good results but not perfect.
For virtualdub, there is also the issue of frame rates. I would like the output to be 30FPS from 60 interlaced fields and I am not sure how to control this. Any input on the frame rate or reducing the blocking on the edges was would be greatly appreciated. |
| se7six |
| Posted: Sep 19 2011, 03:35 AM |
Here is a pretty good deinterlace plugin that I use quite often for my 1080i camcorder videos. It supports multi-threading also.
Muksun Deinterlace v3.1 (VirtualDub)
-------------------- System 1 Intel Q9550 @ 2.83GHz Gigabyte EP45-DS3R 4GB Corsair Dominator DDR2-1066 896MB BFG NVIDIA GTX 260 OC2 (216)
System 2 Intel Q9400 @ 2.66GHz ABIT IP35-Pro 4GB Corsair DHX DDR2-800 512MB XFX NVIDIA 8500 GT |
| jpsdr |
| Posted: Sep 19 2011, 07:23 AM |
The best de-interlacer filter i know is QTGMC for avisynth, but it needs a lot of CPU power, and it's slow. |
| evropej |
| Posted: Sep 19 2011, 01:49 PM |
Thanks for your suggestions, I will test them out and see how it goes. I have plenty of CPU power =] |
