Joining 2 Avi Files
tamachan
Posted: Feb 12 2003, 11:46 AM
Can anyone help me?
and tell me how you can join 2 avi file with VirtualDub???
thank you very much.
minion
Posted: Feb 12 2003, 10:17 PM
First you have to make sure that Both files are Exactly the same in Format and Resolution and Compression and Audio format and audio sample rate, then load in the First AVI file then add the second file by useing the "Add segmented AVI" function, then set the audio and vudeo to "Direct stream Copy" then "save as AVI", and that is it....
tamachan
Posted: Feb 13 2003, 05:00 AM
But when i add segmented AVI the sound becomes swapped, its like in the beginning the sound is the 2nd AVI sound and in the middle it is the first one. Any suggestion???
Thx
2 replies since Feb 12 2003, 11:46 AM Track this topic | Email this topic | Print this topic
