Could Not Open Log File For Reading, error code -2
tsiantasg
  Posted: Aug 28 2002, 01:24 PM
I try to use virtual dub with 2 pass.
I put the filters and divx 5.01 for the compression and
a.in the configuration of the divx 5.01 i choose 1 pass.
b.Then back in virtuadub and file/save as avi with name test, and i checked add job.
c.Again in the configuration off the divx 5.01 i choose 2 pass.
d.Then back in virtuadub and file/save as avi with name test2, and i checked add job.
e.I choose file/job control and start
f.when it finish the first job and going to start the second job (2-pass) it stopeed with error
Could not open log file for reading
and when i click on the job description i take this message
cannot start video compression
The source image format is not acceptable (Error code -2)
Please if anyone can help
Thanks
BaronVlad
Posted: Aug 28 2002, 04:45 PM
Terrorhörnchen
Thats often, if you used GKnot before, cause you deleted the logfile of your last movie, but also if you did not, you could try:
1) reinstall the codec or better (because 1) may only work once !)
2) scan your harddisks for the files "divx.log" and "mvinfo.bin" (normally directly C:/. Then open the Divx-Menu in VDub and in the main page logfile -> select: divx.log (from your search) and mvfile -> select: mvinfo.bin (also from your search) After this: activate "protect log/mv file"
Hochachtungsvoll
BaronVlad
ProfDrMorph
Posted: Aug 29 2002, 05:37 PM
did you mean 2-pass First Pass by "i choose 1 pass"? This may be your mistake: the first pass must be 2-pass First Pass and the other pass must be 2-pass Second Pass.
2 replies since Aug 28 2002, 01:24 PM Track this topic | Email this topic | Print this topic
