| wudt |
| Posted: Aug 27 2002, 01:33 AM |
I am a novice, so please be patient.
Using screen capture, I created a avi file and I also have a separate wav file explaining the screen capture activities. .
The original file sizes are avi=340 KB and wav=864 KB.
I compressed the avi file using VD with Divx Codec and I compressed the wav file with mp3 format. The file sizes are now avi=86 KB and wav=118 KB.
When I tried to dub the avi file using VD, by opening the avi and wav files and do a Save As. The dubbed file size is 1,652 KB.
Is there a way to reduced the size to close to 200 KB? Also, why is the dubbed file size so much larger than the sum of the original files.
Thanks.
D.T. |
| ChristianHJW |
| Posted: Aug 27 2002, 05:21 AM |
You certainly forgot to set 'video' to 'direct stream copy' when using 'save as', now your video is uncompressed YUV data ( huge ) ...
