Does Audio Clip Or Pop
Fallhard
Posted: Oct 19 2014, 11:54 AM
Will the audio click or pop between AVI segments when using "Append AVI segment" in "direct stream copy" mode?
Or when I edit out a part of a single AVI, will the newly joined ends of the edit make the audio click or pop?
And if it does, what can I do about it?
I am using Uncompressed Raw Audio and Video.
Posted: Oct 19 2014, 03:21 PM
Appending shouldn't make a pop/click
The audio should be cut on a frame, so shouldn't pop/click
However this means the audio cuts aren't exactly at the same point as the video frame cut (only slightly off, but still...)
The only way around that is to recompress the audio instead
Probably would have been much faster to have just tried it and seen what happens?
1 replies since Oct 19 2014, 11:54 AM Track this topic | Email this topic | Print this topic
