| rmanal |
| Posted: Sep 21 2014, 03:00 PM |
I have a MKV file with: Video: 264 flow Audio: AC3 flow Subtitle
and I would like to create an AVI file with DIVX, PCM or MP3 and subtitle incrusted.
I have all the ACM/VFW and other directshow filter necessary to manage DIVX, H264, MP3 and AC3.
Is it possible to do it with VD (for instance I have not found how)?
Thank you Rmanal |
| rmanal |
| Posted: Sep 24 2014, 07:17 AM |
Nobody? |
| -vdub- |
| Posted: Sep 24 2014, 12:02 PM |
Did you try AVI-Mux GUI http://www.alexander-noe.com/video/amg/ |
| Altaf |
| Posted: Sep 24 2014, 06:34 PM |
| QUOTE (rmanal @ Sep 21 2014, 07:00 PM) | Hi,
Thank you Rmanal |
Open File as FFMpeg Supported Files. Video direct stream copy, Audio - PCM or MP3, save. After you can as usual... |
| raffriff42 |
| Posted: Sep 24 2014, 10:27 PM |
| QUOTE (rmanal @ Sep 21 2014, 03:00 PM) | | and I would like to create an AVI file with DIVX, PCM or MP3 and subtitle incrusted. |
By "incrusted," do you mean "burned in," (permanent) or do you mean muxed in?
Burning: use the Subtitle filter or the ffdshow/ffvdub plugin. I know very little about the first option, but I wrote a tutorial on the second.
Muxing: VirtualDub does not support muxing subtitle streams. Use VirtualDubMod or something else.
Handbrake does both types of subtitle and is a good encoding utility all around. It does not support AVI output though; MP4 or MKV only.
EDIT "burned in" also known as "hard" subtitles; "muxed" also known as "soft" subtitles.
This post has been edited by raffriff42 on Sep 24 2014, 11:35 PM |
| rmanal |
| Posted: Sep 27 2014, 10:19 AM |
Thank you for your answer @vdub: I would prefer to stay with VD
@Altaf: FFMEG does not read AC3 nor subtitle
@raffriff42: I mean "burned in". I will try your tutorial |
| rmanal |
| Posted: Oct 2 2014, 06:20 AM |
So no possible by using VD, instead of reapping the flow and the remux everything: too long.
What is the best actual and still maintain software to convert MKV to AVI/MP4/MOV/other by being able to select the flow you want to keep and to "burn in" the subtitle?
Thank you |
| rmanal |
| Posted: Oct 5 2014, 11:01 AM |
Nobody? |
| Posted: Oct 5 2014, 11:28 AM |
Extract the subtitles from the mkv Use any subtitle filter to draw the subtitles on the video Recompress the video
| rmanal |
| Posted: Oct 6 2014, 06:09 AM |
I would prefer to use external software to have something completly integrated. Do you know one? |
| ALbino |
| Posted: Oct 6 2014, 06:42 AM |
Handbrake and FFMPEG will let you do burn in subtitles:
https://trac.handbrake.fr/wiki/Subtitles
https://trac.ffmpeg.org/wiki/HowToBurnSubti...titlesIntoVideo
For example with Handbrake, using the Command Line you would add:
--subtitle-burn
Hope this helps.
| rmanal |
| Posted: Oct 12 2014, 10:07 AM |
thanks |
