Fade To Black
BogMod
Posted: Aug 13 2014, 01:10 AM
So yeah I am not looking to do anything super complex here. I just need to figure out how to say take make the video, and just the video, fade to black over the last second or two of the video. I have tried looking around and lots of things have talked about using Blend or keyframes but thats all greek to me so...can anyone help?
raffriff42
Posted: Aug 13 2014, 02:28 AM
1.
Filters...
Add...
Fill...
(accept the default Fill filter settings)
4.
Blend...
View Curve Editor...
Go to last frame, Shift+Left click the curve timeline at 100% blend...
Go to an earlier frame, Shift+Left click the curve timeline at 0% blend...
That's it! Preview your effect.
(PS I just learned this trick yesterday)
BogMod
Posted: Aug 21 2014, 01:53 AM
Ok that worked great. Exactly the thing I wanted in terms of how it looks. There is a problem though.
Normally what I do when I need to play around in virtualdub is just replacing one audio track with another. So I have to set it at direct stream copy and that works great. However when I do these changes when I try to then Save as .avi and then play that avi file it is so choppy and laggy. Any advice?
raffriff42
Posted: Aug 21 2014, 02:19 AM
Sounds like you are not compressing your video.
See this recent thread, Compression Encoder, which one to use?
3 replies since Aug 13 2014, 01:10 AM Track this topic | Email this topic | Print this topic
