| zdf |
| Posted: Aug 6 2014, 01:33 PM |
I am trying to make a time-lapse video.
- The resolution of pictures is 2304/1536. - There are about 3500 pictures (~1.3GB). - I have cropped the pictures to 2304/1296 (16:9). - The frame rate is set to 24 (8 times faster). - Compressor: Xvid.
If I try to maintain the quality, the output is much too large (3.5GB, at least).
If I try to reduce the size, the quality is not satisfactory.
I don’t know a thing about compression/video, but common sense tells me that the output should be smaller than the total size of the pictures and the quality must be the same.
Thank you. |
| Posted: Aug 6 2014, 02:19 PM |
Video and still compression have different tasks and are designed differently Still compression is all about smallest size/best quality Video compression has to trade off for frame rate and cpu usage + it's designed to be compressing a series of pictures that are pretty similar to each other
It would help if you'd given the settings you used - without them, I'll just have to guess at a starting point -> tbh I'd use x264vfw instead of xvid for that size video frames
XVid suggested starting settings Profile: unrestricted Encoding type: single pass Target quantizer: 4 Zone options button-> tick these: begin with keyframe, chroma optimizer enabled -> click ok Quality preset 'more' button -> motion search precision 6, vhq mode 4, tick use vhq for bframes too, use chroma motion ->click ok
Try that and change the target quantizer to adjust the file size
