Call Virtualdub Programmatically, Logo by videos dynamically
magdy.a
Posted: Jul 20 2014, 03:40 PM
Hey guys,
I was wandering if I can call virtualDub dynamically from another project to load a video and set some filter (logo) and generate the result in some location.
thank you
Posted: Jul 20 2014, 03:49 PM
Virtualdub can be run with cmdline script+params, so as long as you can call a program from your project then yes it's possible
Info is in the help file and various places here
Script language (a bit out of date)
http://www.virtualdub.org/docs/vdscript.txt
A search for 'vdscript' has plenty of examples
http://forums.virtualdub.org/index.php?act...ghlite=vdscript
Basically, you write a script and call virtualdub.exe (or vdub.exe in a .bat file) with the script and whatever params you want
To write a script, the easiest way is to set it all up in virtualdub and then 'save queued' - the virtualdub .jobs file will then have the script in it
Edit that script as shown in the above search to remove any bits you don't need, and change the source+dest to parameters
eg these .bat methods of using virtualdub
http://forums.virtualdub.org/index.php?act...880&hl=vdscript
http://forums.virtualdub.org/index.php?act...931&hl=vdscript
magdy.a
Posted: Jul 20 2014, 04:03 PM
thank you very much sir
2 replies since Jul 20 2014, 03:40 PM Track this topic | Email this topic | Print this topic
