| Sanachan1977 |
| Posted: Sep 2 2002, 08:27 PM |
I have a Creative Labs Video Blaster DVCR capture card, and am currerntly using Virtual Dub. I am trying to capture video (just from the TV signal for now) and converting it to an AVI.
The video codec I am using is Huffyuv v2.1.1
When I select "set custom format" option from the video menu, and attempt to set the data format to YUY2 or 24-bit RGB, I get "Error 418: Unsupported video format" I have tried many different combinations of resolutions and none of them seem to work with these particular data formats.
Is there another or different codec/driver that I should d/l and install? Or is the problem something else?
Thanks for your time and patience, Sanachan1977 |
| SillKotscha |
| Posted: Sep 3 2002, 06:39 PM |
smart Moderator
first you'll have to choose your compression codec (in your case huffyuv) then choose your desired format...
be aware of your driver - not every driver supports every resolution!! and not every resolution supports the data format of your choice.
have a closer look here:
VirtualDub documentation: Capture
