Altirra Does Not Start Correctly
Coronada
Posted: Nov 1 2011, 03:06 PM
I am a big fan of altirra. Now I have a problem only on one computer, others are fine:
After Startup it reports (via Dialog)
Altirra Error
The emulated system has stopped due to a program error. Please
choose an action.
You can also try restarting with different emulation settings to
improve compatibility:
(lots of settings only two active:)
#Change wideo mode: NTSC
#Disable debugging options
| DEBUG | |Warm Reset| | Restart | | Pause |
(End of Dialog)
If I press DEBUG then the program disassembly is there and can be stepped through.
If I press F8 (Run) afterwards everything runs fine.
How can I find out what causes the error at startup?
Is there any log or somthing?
Posted: Nov 6 2011, 10:40 PM
Sorry, but this board is only for VirtualDub discussion. Please send queries about Altirra by email or post them to the blog comments for 1.9: http://virtualdub.org/blog/pivot/entry.php?id=337
1 replies since Nov 1 2011, 03:06 PM Track this topic | Email this topic | Print this topic
<< Back to Off-Topic
