HI, pls don;t take me wrong, i like virtualdub, and use a lot. i see the virtualdub is more on the linear editing, say if you need to join 5 avi from 1 to 5 in oder together it's not a small job to change the sequence from 12345 to 53241 . but in NLE it's easier by just cut drop or insert or drag and drop/ i like virtauldub stream copy which by far the best to cut and join the avi,but as i need to think what to edit, i need more visually timeline. if thers' a GUI to make tim line,i think it's possible to do it. using virtauldub as the core engine. |
