| Psycogeek |
| Posted: Mar 25 2014, 10:45 AM |
That was Really easy, certannly not like the last time. This FFMpeg plug is just loading stuff into the 32bit like clockwork.
All this really helps a lot, I have been suffering in my own self made disaster for too long, thanks.
Then I did need to direct stream, for simple audio adjust things so. I get the FCC handler plug-ins. What seperated codec items would you recommend for maktroka and AVC if I have a great fear of FFshow? I think i am remembering where some of this did not go well. |
| Posted: Mar 25 2014, 01:35 PM |
For the other plugins to do direct stream copying you'll need to find a vfw codec for each particular codec used if you want to skip ffdshow You'll get an error message with the video codec fourcc in, and you can just google for it eg> codec vfw xvid Audio codecs have a number instead and you can google eg> acm codec 2000 (2000 is ac3)
There are links to some acm codecs in my sig
