Deshaker, how to instal it
Posted: Mar 16 2014, 07:46 PM
Ok, one last try
Here is a virtualdub that I've put all the right bits in
https://dl.dropboxusercontent.com/u/1702491...lDub-1.10.4.exe
It's a self-extracting archive, so double click it and let it extract everything to a new folder (default is a folder called Virtualdub at the same place the file is)
Try starting the virtualdub in that new virtualdub folder
Deshaker should show up - it does here
If it doesn't, then there's something missing on your pc that it needs
You'll have to speak to deshakers author about that
timoto
Posted: Mar 17 2014, 10:25 AM
Thanks for your help
16 replies since Mar 14 2014, 01:43 PM Track this topic | Email this topic | Print this topic
Pages: (2) 1 [2]
<< Back to General Discussion
