Couldn't Locate Decompressor For Format 'rv24'
rotbart
Posted: Jan 30 2014, 10:38 PM
I've got the following error message when opening an .avi file with VirtualDub 1.10.4 on Win7:
Couldn't locate decompressor for format 'RV24' (unknown)
Background information: The video file was created by VLC's record function while grabbing directly from some video capture device. The video file can be played in VLC flawlessly. The media info says the codec is "24 bits RGB (RV24)".
I suppose that the .avi file is using some unusual raw video format. However, I couldn't find any codec for 'RV24'. I have already tried ffmpeg-tryout.
Any suggestions?
Thanks and best regards,
rotbart
v0lt
Posted: Jan 31 2014, 04:41 AM
Unload sample somewhere.
rotbart
Posted: Jan 31 2014, 09:25 AM
Sample file: http://91.250.xxx.yyy/sample.avi (deleted)
raffriff42
Posted: Jan 31 2014, 01:46 PM
Since nothing seems to decode it (I tried), I would use VLC to convert it to...
* MP4/H264/AAC for viewing, or
* AVI/M-JPEG/WAV for editing (use max MJPEG bitrate, 9999 kbps)
malky
Posted: Jan 31 2014, 03:21 PM
Beat me to it.
v0lt
Posted: Jan 31 2014, 06:13 PM
Open the file in any HEX-editor. Replace 'RV24' at the beginning of the file to zero and save the file. Then open the file in VirtualDub.
rotbart
Posted: Jan 31 2014, 06:29 PM
QUOTE (v0lt @ Jan 31 2014, 06:13 PM)
Amazing, it works! Thanks! Although the image is flipped vertically for some reason, but it's easy to fix within VirtualDub.
So it seems the FOURCC code was wrong. I already tried several RGB FOURCC codes (http://www.fourcc.org/rgb.php), but only those which you can enter into VirtualDub, so I didn't try the 00 00 00 00 code. dry.gif
raffriff42
Posted: Jan 31 2014, 06:54 PM
Nice tip there v0lt, thank you.
7 replies since Jan 30 2014, 10:38 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
