What I Not Found In Proram, ... or in help
Vgyuri
  Posted: Nov 24 2013, 04:20 PM
How can I insert picture into the edited video?
malky
Posted: Nov 24 2013, 11:31 PM
I think you have to install AviSynth and use a script.
x=avisource("C:\path\to\video\clip.avi").assumefps(25)
y=ImageSource("C:\path\to\image\clipboard01.jpg",end=75,fps=25).ConvertToYV12()
z=audiodub(y, blankclip(x))
#yy=wavsource("C:\path\to\audio\some.wav")
#z=audiodub(y, yy)
z++x
#image and video must have same resolution width x height and frame rate
#this image has 75 frames at 25 fps = 3 seconds on screen
#line 3 is for a silent clip
# if audio is required, remove the # from lines 4 and 5 and insert a # in line 3
If you want to insert the image somewhere in the middle of the video, it might be:
vid    = avisource("clip.avi")
start  = vid.trim(0,545)
end    = vid.trim(546,1594)
middle = ImageSource("C:\Users\Superuser\Desktop\Clipboard01.jpg",end=75,fps=25).ConvertToYV12()
middle = audiodub(middle, blankclip(vid))
#yy = wavsource("C:\Users\Superuser\Desktop\titanic.wav")
#middle = audiodub(middle, yy)
start++middle++end
#the middle will be inserted beginning at frame 546 using image
raffriff42
Posted: Nov 25 2013, 01:01 AM
If you are not familar with Avisyth, the Logo Filter for VirtualDub is easier.
Here's a screenshot showing a PNG image with alpha channel:
meowmeow
Posted: Nov 25 2013, 01:19 PM
I hope with curve editor it can add many-many logos at different frames of video.
Curve editor can blend videos too? What if I want to do mosaic from four videos?
raffriff42
Posted: Nov 25 2013, 07:33 PM
To make multiple images with the Logo filter, you would add multiple filter instances. Curve Editor does not work with this filter. If you want that kind of advanced processing, I think Avisynth would be easier.
Posted: Nov 25 2013, 07:48 PM
Just tested the internal logo filer and the one you gave a link to
Both work fine with the curve editor and blending?
meowmeow
Posted: Nov 25 2013, 08:04 PM
QUOTE (dloneranger @ Nov 25 2013, 07:48 PM)
Plays, blends, encodes, plays....
How merge & blend layers works?
Posted: Nov 25 2013, 08:30 PM
No idea, I use an older virtualdub that doesn't have the merge and name outputs thing
I tried it when it appeared, and a quick look at the blend layers filter is an easy one to explain
add a filter eg greyscale
right click on that filter and 'name output' I called it G1
add a blend layers filter, I used normal 100% , click ok to close the blend layers dialog
right click on blend layers filter - add input - right click on (no connection) - select 'source'
right click on blend layers filter - add input - right click on (no connection) - select 'g1'
configure the blend layers filter - move the slider to change the % and it'll move between grey and normal
meowmeow
Posted: Nov 25 2013, 09:15 PM
QUOTE (dloneranger @ Nov 25 2013, 08:30 PM)
Ahh, the missing link meowmeow was looking for!
http://i.imgur.com/UdlHiyv.jpg
Step closer to joining two videos together.
raffriff42
Posted: Nov 26 2013, 12:05 AM
a quick look at the blend layers filter is an easy one to explain...
This is the first time I've seen Layers explained. Thank you. And I stand corrected on Logo+blend+curves.
meowmeow
Posted: Nov 26 2013, 01:16 AM
QUOTE (meowmeow @ Nov 25 2013, 09:15 PM)
Done.
http://i.imgur.com/aE9NVjC.gif
Or frameserve from another VD instance
Posted: Nov 26 2013, 05:38 AM
Done
meowmeow
Posted: Nov 26 2013, 05:49 AM
QUOTE (meowmeow @ Nov 26 2013, 01:16 AM)
Found: http://www.trevlac.us/FilterDocs/
Video overlay, picture in picture filter plug-in!
Crashed when try to open file into 0x0 selection by mistake.
Crashed when try to blend it.
But has source codes and much easier than using the interpolate/fill/perspective/blend layers way tongue.gif
12 replies since Nov 24 2013, 04:20 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
