Scene Detection, Extract scenes as separate AVIs?
Newstech
Posted: Sep 17 2002, 11:34 AM
Life would be great if there were an automatic way to detect scenes and save them as separate AVIs. I saw a post once that suggested AVISynth might contain that capability, but the program is overwhelming. Has anyone figured out a way to do this?
Posted: Sep 19 2002, 04:30 AM
Someone might be mistaken; I don't recall AVISynth having any capability like that. AFAIK the only way to do this is to do it manually. wacko.gif
Newstech
Posted: Sep 19 2002, 12:22 PM
I just discovered Stoik's freeware Video Converter.
http://www.stoik.com/downloads/downloads_frm.htm
I am having some luck with getting automatic scene detection/separation, but still have to work on it.
First try, it only detected the first shot transition.
Then I twiddled the threshold values in the .ini file. Right now I'm at:
HueThreshold=1
SatThreshold=0
ValThreshold=0.4
DisThreshold=0.4
which produced a few false hits in a capture with about 10 shots, and missed one. The sequence was shot in a garden, so there was green everywhere. It would probably perform better on better-defined changes.
(I also used VirtualDub first to clean up around the transitions, because I had some tripod shake as I shut off the camera. Real cheap tripod. wacko.gif)
I also got trashed audio in two of the clips (using MP3). I don't understand why it was only bad on two, and am going to experiment some more with different or no compression.
All in all, I'm hopeful.
--Steve
beach
Posted: Sep 19 2002, 09:19 PM
Why don't you simply try "scenalyzer" ??
SynchronousArts
Posted: Sep 19 2002, 10:24 PM
I looked up Scenalyzer, It looks like it only works with DV video, the latest version ScenalyzerLive works with 1394 input cards. It sounds cool, but I don't use DV. Is there a version that works with Open DML AVIs with any codec?
Atomi
Posted: Oct 10 2002, 02:12 PM
VirtualDub 1.4.9.2 VCR + SYNC at
http://www.virtualdub.net/
will solve this. The probelms is that there is very little documentation and even that's partly in German.
5 replies since Sep 17 2002, 11:34 AM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
