How To.. Batch Wizard - Multi Video Drag And Drop, A Guide (without the text edit details)
-vdub-
Posted: Sep 2 2013, 03:42 AM
A guide overview since I make no guide to show you how to do it in full. Since sometime this will be fixed by Phaeron and so then guide isn't needed. Until a fix fix is made it can be done like so..
1. For avi files these should all work as is so you don't need this guide. If it doesn't work maybe this guide overview works for you
2. Open a video and add video load plugin so able to decode the video when it is loaded
3. Without adding any other filters or settings changing - File > Save Processing Settings (anyfilename.vdscript)
4. Close the above video then open Batch Wizard and drag and drop the same video as above to Batch Wizard. Select a you will save the avi then exit Batch Wizard which will auto save a virtualdub.jobs file
5. Locate virtualdub.jobs and anyfilename.vdscript in the Virtualdub main folder or in other places you saved them to. Open each of those and compare see the differences to know what needs to be changed In a saved virtualdub.jobs file for multiple video drag and drop with Batch Wizard
6. Try the Batch Wizard first as Phaeron may have made changes so you don't need to do this
7. Try first if in doubt, Drag and Drop two small videos to the Virtualdub Batch Wizard and process the batch job to see if saved videos are ok. Or to test if needing to do 1-5 above
8. When have need to add different video containers .mp4, mkv etc using multiple drag and drop to Batch Wizard. Do so one container type type at a time..
a. Add all mp4 close batch wizard then edit the anyfilename.vdscript save with different anyfilename2.vdscript
b. Open batch wizard then process all mkv videos after edit anyfilename.vdscript for flv video load
c. Add both scripts to Process Jobs manager if not included then able process all together
0 replies since Sep 2 2013, 03:42 AM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
