Pb With Direct Show Plugin
rmanal
Posted: Apr 5 2014, 04:29 PM
I have tried to use the last directshow filter, provided here http://forums.virtualdub.org/index.php?act...=ST&f=7&t=15093, but whatever I try to put the x32 or x64 plugin in corresponding folder, I can never select directshow filter in the open box of VD.
This version is dated 2012. I'm still using one dated 2008, working quite well.
What have I done wrongly?
Thank you
Rmanal
raffriff42
Posted: Apr 5 2014, 05:17 PM
If you're saying you are using VirtualDub version 1.8.x, it is very old. Try again with version 1.10.4
http://sourceforge.net/projects/virtualdub...virtualdub-win/
rmanal
Posted: Apr 5 2014, 10:30 PM
No, of course i'm using the last one. The version of 2008 is Dshow plugin.
raffriff42
Posted: Apr 6 2014, 12:33 AM
EDIT apologies, I see now you are saying the old DirectShow plugin works OK, but the new one doesn't.
This post has been edited by raffriff42 on Apr 6 2014, 03:30 AM
Posted: Apr 6 2014, 06:54 AM
I have a Windows 7 32-bit.
Extract "DShowInputDriver.vdplugin" out of the "DShowInputDriver-v0.93.zip" into subfolder plugins32 of VirtualDub.
(exemple C:\Program Files\VirtualDub 1.10.5\plugins32\DShowInputdriver.vdplugin)
VirtualDub 1.10.4 (build 35491) and VirtualDub 1.10.5 (build 35512) are working fine with DirectShow plugin v0.93.
rmanal
Posted: Apr 18 2014, 09:51 AM
I have redone a complete installation of VD32 and VD64 with DShowinputdriver 0.93:
- With VD32, I can not select it
- With VD64, it works well
In the DShowInputDriver-0.93.zip, I have:
release
DShowInputDriver.vdplugin => I have selected this one for the 32bits version
x64
release
DShowInputDriver.vdplugin => I have selected this one for the 64bits version
Could you send me the DShowInputDriver.vdplugin you have used for the 32bits version?
Posted: Apr 18 2014, 02:17 PM
I've got it from here:
If you have put the "DShowInputDriver.vdplugin" in the "plugins32" subfolder of where VirtualDub.exe is installed, then I do not have an explanation why it should not work.
In VirtualDub version 1.10.5 you should see it when you click the Options-menu -> Plug-ins...
rmanal
Posted: Apr 22 2014, 09:00 AM
What is strange is that the post if from 2008, as my "old" file, but in the zip you have a 2012 file.
Do you have a mail where I can send you the file I have for VD32?
Posted: Apr 22 2014, 06:33 PM
When you read the first post in the thread
thus the post of 10 jan. 2008, you will see at the end:
"This post has been edited by phaeron on Apr 21 2012, 11:06 PM"
That was the last time that Phaeron published a new version (version 0.93) of his DirectShow plugin for VirtualDub,
and that is also the "Date modified" of the DShowInputDriver.vdplugin files (one for 32-bit and another one for 64-bit).
It has no use that you would send me your version of the 32-bit DShowInputDriver.vdplugin file.
I can not help you with that.
The only thing that I can repeat, once again, is that if you put that 32-bit version of the DShowInputDriver.vdplugin file into the plugins32 subfolder of where your VirtualDub.exe (32-bit) is in, it should be available in the File > Open video file... dialogbox, when clicking at Files of type ... "DirectShow input driver" is just before the last entry in that list.
If it is NOT there, then I have totally NO idea what could be wrong.
rmanal
Posted: Apr 23 2014, 12:53 PM
I just wanted to check that I have the same file as you, because as I have said, and you have probably not read, I have of course put the plugin file in the right folder, but nothing appears even in the option/plugin menu. Furthermore it is woking on x64.
If anybody else has an idea why on my PC it could not work?
I'm under 7 pro, with a laptop.
rmanal
Posted: Apr 23 2014, 01:58 PM
I have found a log: in the virtualdub log, it is said: can not load bla bla plugin .... it is not a valid win32 application.
so again I think I don't have the good plugin file, instead I have downloaded it 4 times.
Posted: Apr 23 2014, 02:20 PM
So you can check
http://www.virtualdub.org/beta/DShowInputD...Driver-0.93.zip
The 32bit plugin
192512 bytes
MD5 hash 9B966456FF4917540CC626ADCF908E6F
The 64bit plugin
241664 bytes
MD5 hash 2BA07D8BAB3355209359292F4EF1B2D6
rmanal
Posted: Apr 24 2014, 07:47 AM
Yes, I have found the issue. Thank you very much dloneranger.
In fact i'm using izarc and for a reason I don't know, when I requested extract of the plugin, it performs in fact two extractions: the 32, then the 64, replacing the 32. I have asked it to confirm extraction, then cancel the seond one.
Don't ask me why...
And now it works.
I have another question/issue but I will open a new topic.
Sorry to be so noob but if we even can not trust software like Izarc...
12 replies since Apr 5 2014, 04:29 PM Track this topic | Email this topic | Print this topic
