| venya |
Posted: Feb 9 2003, 06:48 PM |
When VirtualDub is running and I try to launch second instance of VirtualDub do to something else it crashes (the second instance). Then first instance crashes on exit
It works for me before and I don't know when it started, maybe after I have upgraded VirtualDub to 1.4.13 |
| Posted: Feb 10 2003, 12:24 AM |
Hmm. Never heard of that before. My suggestion is to empty the VirtualDub "plugins" folder (move all the files somewhere else) and try it again. If that works, then one of your plugin filters is at fault.
| venya |
| Posted: Feb 10 2003, 06:36 AM |
It does not helps :-( I have try to remove some plugins and even rename Plugins folder - plugins not loaded in the list but VirtualDub still crashes |
| Posted: Feb 10 2003, 07:13 AM |
Well, my guess was wrong. What error messages do you see from VirtualDub and/or Windows when the crashes occur? (The more detail you can give, the better.)
