| Posted: Jun 3 2008, 07:17 AM |
Anyone got some weirdly encoded Huffyuv videos to test?
http://www.virtualdub.org/beta/VirtualDub-....8.X2-test2.zip http://www.virtualdub.org/beta/VirtualDub-...test2-AMD64.zip http://www.virtualdub.org/beta/VirtualDub-...X2-test2-src.7z
This version contains an internal Huffyuv decoder. It's designed to handle vanilla 2.1.1 encoded files as well as those that use ffmpeg extensions (YV12 and adaptive Huffman). It's a bit less optimized and is probably a bit slower than the stock decoder, but the differences are that this decoder is also fully functional in the 64-bit build and it does full checking in both the Huffman tree and bitstream decoders.
If you already have a Huffyuv decoder installed, enable the internal video decoders in Options > Preferences > AVI to use the built-in one.
I'd be interested if someone has a video which doesn't decode properly or if they're able to crash the decoder with a malformed file. |
| stephanV |
| Posted: Jun 3 2008, 07:26 AM |
With ffdshow Huffyuv, YV12, Plane, adaptive tables after about 8 frames I'm getting
| CODE | | Error decompressing frame xx: Internal error: Insufficient space for Huffman decoding tables |
for the rest of the frames.
[EDIT] It seems it only happens with adaptive tables.
| Posted: Jun 4 2008, 05:51 AM |
Eeeeenteresting. I don't suppose you can post a 1-frame sample somewhere?
The error in question has to do with the amount of space required for the decoding tables -- specifically, it has to do with the maximum length of code that can be encountered with each leading '1' bit position. I had assumed that this couldn't exceed 2x, but apparently I was wrong. |
| stephanV |
| Posted: Jun 4 2008, 06:41 AM |
http://s000.tinyupload.com/index.php?file_...896445&gk=forex (1.3 MB, 20 frames)
It seems that the decoding error *always* starts at frame 7 of a compressed file. The same frames stay undecodable (is that a word?) though if you cut that file with DSC afterwards.
Another thing: I also I got this crash when trying to save a selection (using ffdshow to compress) on a non-zero starting point.
| CODE | VirtualDub crash report -- build 29837 (release) --------------------------------------
Disassembly: 0056aa40: 6aff push 0ffh 0056aa42: 68d8cb5a00 push 005acbd8 (RtlUnwind@16+db5c) 0056aa47: 64a100000000 mov eax, fs:[00000000] 0056aa4d: 50 push eax 0056aa4e: 64892500000000 mov fs:[00000000], esp 0056aa55: 83ec6c sub esp, 6ch 0056aa58: 53 push ebx 0056aa59: 55 push ebp 0056aa5a: 56 push esi 0056aa5b: 8bf1 mov esi, ecx 0056aa5d: 8b4634 mov eax, [esi+34h] 0056aa60: 33db xor ebx, ebx 0056aa62: 33ed xor ebp, ebp 0056aa64: 385e4c cmp [esi+4ch], bl 0056aa67: 57 push edi 0056aa68: 895c2418 mov [esp+18h], ebx 0056aa6c: c744241c010000 mov dword ptr [esp+1ch], 00000001 00 0056aa74: 8944242c mov [esp+2ch], eax 0056aa78: 885e4d mov [esi+4dh], bl 0056aa7b: 7525 jnz 0056aaa2 (VDVideoCompressorVCM::CompressFrame+62) 0056aa7d: 8b4e28 mov ecx, [esi+28h] 0056aa80: 3bcb cmp ecx, ebx 0056aa82: 750b jnz 0056aa8f (VDVideoCompressorVCM::CompressFrame+4f) 0056aa84: 395e24 cmp [esi+24h], ebx 0056aa87: 7419 jz 0056aaa2 (VDVideoCompressorVCM::CompressFrame+62) 0056aa89: 895c241c mov [esp+1ch], ebx 0056aa8d: eb13 jmp 0056aaa2 (VDVideoCompressorVCM::CompressFrame+62) 0056aa8f: 83c0ff add eax, 0ffh 0056aa92: 3bc3 cmp eax, ebx 0056aa94: 894634 mov [esi+34h], eax 0056aa97: 7406 jz 0056aa9f (VDVideoCompressorVCM::CompressFrame+5f) 0056aa99: 895c241c mov [esp+1ch], ebx 0056aa9d: eb03 jmp 0056aaa2 (VDVideoCompressorVCM::CompressFrame+62) 0056aa9f: 894e34 mov [esi+34h], ecx 0056aaa2: 8b4e38 mov ecx, [esi+38h] 0056aaa5: 3bcb cmp ecx, ebx 0056aaa7: 7412 jz 0056aabb (VDVideoCompressorVCM::CompressFrame+7b) 0056aaa9: 8b6e44 mov ebp, [esi+44h] 0056aaac: c1fd02 sar ebp, 02h 0056aaaf: 8bc1 mov eax, ecx 0056aab1: 03e9 add ebp, ecx 0056aab3: d1f8 sar eax, 1 0056aab5: 3be8 cmp ebp, eax 0056aab7: 7d02 jge 0056aabb (VDVideoCompressorVCM::CompressFrame+7b) 0056aab9: 8be8 mov ebp, eax 0056aabb: 3bcb cmp ecx, ebx 0056aabd: 8bbc2490000000 mov edi, [esp+90] 0056aac4: 8a07 mov al, [edi] <-- FAULT 0056aac6: 88442413 mov [esp+13h], al 0056aaca: 0f84a1020000 jz 0056ad71 (VDVideoCompressorVCM::CompressFrame+331) 0056aad0: f6460802 test [esi+08h], 02h 0056aad4: 0f8597020000 jnz 0056ad71 (VDVideoCompressorVCM::CompressFrame+331) 0056aada: b867666666 mov eax, 66666667 0056aadf: f7e9 imul eax, ecx 0056aae1: c1fa03 sar edx, 03h 0056aae4: 8bca mov ecx, edx 0056aae6: c1e91f shr ecx, 1fh 0056aae9: 8d540a01 lea edx, [edx+ecx+01h] 0056aaed: 8d442414 lea eax, [esp+14h] 0056aaf1: 50 push eax 0056aaf2: 8b4654 mov eax, [esi+54h] 0056aaf5: 8d4c241c lea ecx, [esp+1ch] 0056aaf9: 51 push ecx 0056aafa: 89542428 mov [esp+28h], edx 0056aafe: 8b542424 mov edx, [esp+24h] 0056ab02: 52 push edx 0056ab03: 57 push edi 0056ab04: 50 push eax 0056ab05: 53 push ebx 0056ab06: 8b9c24a4000000 mov ebx, [esp+a4] 0056ab0d: 53 push ebx 0056ab0e: 8bce mov ecx, esi 0056ab10: e81bf7ffff call 0056a230 (VDVideoCompressorVCM::PackFrameInternal) 0056ab15: 8b4c2414 mov ecx, [esp+14h] 0056ab19: 8bc1 mov eax, ecx 0056ab1b: 2bc5 sub eax, ebp 0056ab1d: 99 cdq 0056ab1e: 33c2 xor eax, edx 0056ab20: 2bc2 sub eax, edx 0056ab22: 3b442420 cmp eax, [esp+20h] 0056ab26: 0f8e70020000 jle 0056ad9c (VDVideoCompressorVCM::CompressFrame+35c) 0056ab2c: 837c241c00 cmp dword ptr [esp+1ch], 00h 0056ab31: 0f8565020000 jnz 0056ad9c (VDVideoCompressorVCM::CompressFrame+35c) 0056ab37: 3bcd cmp ecx, ebp 0056ab39: 0f8d1e010000 jge 0056ac5d (VDVideoCompressorVCM::CompressFrame+21d) 0056ab3f: 8b db 8bh
Built on Aegis on Tue Jun 03 00:01:06 2008 using compiler version 1400
Windows 6.0 (Windows Vista x86 build 6001) [Service Pack 1]
EAX = 00000001 EBX = 00000000 ECX = 00000000 EDX = 0056aa40 EBP = 00000000 ESI = 0601ce08 EDI = 00000000 ESP = 0579fc88 EIP = 0056aac4 EFLAGS = 00010246 FPUCW = ffff027f FPUTW = ffffffff
Crash context: An out-of-bounds memory access (access violation) occurred in module 'VirtualDub'...
...reading address 00000000...
...while running thread "Processing" (thread.cpp:159).
Pointer dumps:
EDX 0056aa40: d868ff6a 64005acb 000000a1 89645000 00000025 6cec8300 8b565553 34468bf1 ESI 0601ce08: 005e502c 6f2adadc 000000a8 00000000 00000028 002b7808 00000074 0601edf0 ESP 0579fc88: 01cbe788 01cedb38 0579fd54 005e502c 00000000 0579fccc 00000000 00000001 0579fca8: 051c0000 00037200 00000000 00000001 005cba78 051c0000 00001043 01cece98 0579fcc8: 00037200 0579fd74 004c9abc 08a40080 051c0000 004c9c8a 0601c0e8 0601c28c 0579fce8: 00000000 01cefcf8 01cefce0 01cbe788 01cefd00 01cefce0 0579fd54 0579fd48
Thread call stack: 0056aac4: VDVideoCompressorVCM::CompressFrame() 004c9abc: VideoSourceAVI::streamGetFrame() 004c9c8a: _catch$?streamGetFrame@VideoSourceAVI@@UAEPBXPBXI_N_J2@Z$0() 00466c77: VDThreadedVideoCompressor::ProcessFrame() 004671e1: VDThreadedVideoCompressor::ExchangeBuffer() 004685fc: VDDubProcessThread::WriteVideoFrame() 004688ff: VDDubProcessThread::WriteVideoFrame() 746040fc: WINMM!timeGetTime [74600000+40d0+2c] 00468d28: VDDubProcessThread::ThreadRun() 765242eb: kernel32!RaiseException [764e0000+44293+58] 77978464: ntdll!NtDuplicateObject [77920000+58458+c] 7652435c: kernel32!DuplicateHandle [764e0000+442f4+68] 76524379: kernel32!DuplicateHandle [764e0000+442f4+85] 76524379: kernel32!DuplicateHandle [764e0000+442f4+85] 0045c8f0: VDThreadInitHandler() 004f941d: VDThread::StaticThreadStart() 00586c18: _callthreadstartex() 00586cbd: _threadstartex@4() 76524911: kernel32!BaseThreadInitThunk [764e0000+448ff+12] 7795e4b6: ntdll!RtlInitializeExceptionChain [77920000+3e453+63] 7795e489: ntdll!RtlInitializeExceptionChain [77920000+3e453+36]
-- End of report
| Posted: Jun 4 2008, 08:26 AM |
Hmm... ended up having to tweak the table bounds a bit:
http://www.virtualdub.org/beta/VirtualDub-....8.X2-test3.zip http://www.virtualdub.org/beta/VirtualDub-...test3-AMD64.zip http://www.virtualdub.org/beta/VirtualDub-...X2-test3-src.7z
The sandbox that I built that from was a bit old, so it's possible you were hitting a bug that was already fixed on devline... so I've integrated in the current 1.8.1-rc2 source and so this build should be up to date. Try to crash it again.
I'm still trying to figure out why tinyupload.com exists. There aren't ads on it and you don't pay for it, so I can only guess that one of the following applies: someone's bored and naively altruistic, someone's slyly looking to beta test software before putting it into production, or someone's lazy and is trying to get other people to upload porn and warez to his server. |
| stephanV |
| Posted: Jun 4 2008, 09:33 AM |
File decodes properly, crash is gone.
A little question about the UI that I noticed this morning while creating the test file. When No audio is selected, shouldn't most of the options in the audio menu be grayed out? It's no big deal, but the way it is now looks a bit weird in my eyes.
| Posted: Jun 5 2008, 05:23 AM |
Yeah, probably so, but disabling the items tends to be surprisingly confusing to users... another thing to work out in that nebulous date in the future when I have a lot of time and it gets magically easier for me to make UI that doesn't suck. I need to rework the UI, but never got a grip on a good general approach. Shoving the whole thing into one big dialog didn't seem much better.
| sonical |
| Posted: Jun 6 2008, 02:13 PM |
Well I think that VDub UI is quite good, and shouldn't realy be "enhanced" by graying out 101 items. Also, it's good if all options and settings are available even if there is no audio in current file: maybe next one will have it. It actually bothers me, if some kind of soft doesn't allow me to change properties of some settings until I enable them etc.
The only serious improvements for VDub UI I can think of are:
* additional flag in position display, which shows if frame is in the selected range or not * additional exact position displays with selection start and end, so there no need to open the video selection range menu unless to change them manually. Plus a total selected time display, which is handy when figuring out reqiured bitrate to fit the selected crop in specific MBytes. * edit menu option to CROP selection, not only cut/delete selection * one additional (same as old) joblist, for WAV extraction without any hassle. So there is target WAVs list instead of output AVIs list. * handy button to open up filters list, and another handy button to open up configuration of most recently configured filter. * filter preview should have same options of display as preview panes. * when opening up filter preview, current frame could be the same as for main preview windows, rather than frame 0. * audio output device selection * full screen input or output preview option (hotkey)
Well it's a heap of improvements for at least next three versions
Regarding Huffyuv - seems to work well now! |
| Romashulka |
| Posted: Jun 8 2008, 12:28 PM |
I think that all these transformations have second character. The first that needs to be made is a support mkv 30-40 % of users will leave from megui, avidemux (and other programs) to virtualDub VirtualDubmod has been stopped in 2005, but has mkv. Now 2008 year |
