| Bulletproof |
| Posted: Oct 17 2004, 10:24 PM |
Using the latest Virtualdub I opened a video and cut away one frame and attempted to do a direct stream copy save, this causes the program to crash with an access violation, however using Virtualdubmod this does not happen. Another problem is I used a Source .WAV file with a video and cut the video, Virtualdub should accordingly cut the specified .WAV source so it is in sync with the video, so I after cutting the video I wanted to save the newly cut audio as well, so I picked "Save WAV", but virtualdub says that the source has no audio so it will not save, this works in Virtualdubmod however and both of the issues i mentioned worked in the older version of Virtualdub too I think. |
| backwerd |
| Posted: Oct 22 2004, 10:50 PM |
nm |
