Frame Adress, display it ?...
Karel
  Posted: Mar 17 2003, 06:31 PM
I often use the scan video streams for errors, but it's quite tricky to know where in the avi file are the wrong frames (hex adress) ;(I often replace wrong frames with a hex editor, from another copy of my bad avi)
So it would be useful (at least for me wink.gif ) to display the adress next to the frame number...
Pamel
Posted: Mar 19 2003, 01:30 AM
matroska team member
This would also (indirectly) show how much space each frame is taking up. I don't know how useful to the more than a handful of people, but it shouldn't be hard to hard to implement since you already get the offset from the index, right?
Karel
Posted: Mar 19 2003, 04:25 AM
QUOTE (Pamel @ Mar 18 2003, 07:30 PM)
Yes... but what if the index is corrupted and you rebuild it using re-derive key-frame ? I had to do that : it took me hours to figure where were the wrong frames (virtualdub masked 95% of the whole video), correct the header of a single frame chunk using my hex editor... and so on. wacko.gif
And I think it would help having directly the real adress in vdub.
As this feature *seems* easy to implement, why not implementing it ? (okay, I'm perhaps the only one interested ? wub.gif )
2 replies since Mar 17 2003, 06:31 PM Track this topic | Email this topic | Print this topic
