Support For Multichannel Audio
ale5000
Posted: Mar 13 2011, 04:32 PM
It would be nice to have support (at least minimal) for multichannel audio.
QUOTE (fccHandler @ Mar 6 2011, 05:24 AM)
Version 1.4 will now play multichannel AAC correctly but it does so via a downmix to stereo. I don't like having to do this, but I've spent all day on it and I can't figure out how to get VirtualDub to accept multichannel PCM.
I even tried hacking VirtualDub. There is a line in the Riza project, w32audiocodec.cpp, which I thought might be responsible:
// sanitize the destination format a bit
if (mDstFormat->mChannels != 1 && mDstFormat->mChannels !=2)
  mDstFormat->mChannels = 2;
So I tried removing that line, and that did cause him to request 6 channel PCM. But when pressing play it just hangs. I can only guess that there is some other part of the audio pipeline which is not liking multichannel PCM...
New VirtualDub forum
ale5000
Posted: Mar 24 2011, 12:47 AM
If you try to convert from an AVI file with AC3 5.1 audio to AC3 5.1 it say:
Error initializing audio stream compression:
The audio codec cannot compress the source audio to the desired format.
Check that the sampling rate and number of channels in the source is compatible with the selected compressed audio format.
Edit: The same procedure works fine with VirtualDubMod Surround.
1 replies since Mar 13 2011, 04:32 PM Track this topic | Email this topic | Print this topic
