| Mad_Martigan |
| Posted: Feb 10 2003, 08:38 PM |
I love VirtualDub I love Counter-Strike
Is it possible to open up Counter-Strike Demos with Virtual Dub?
Why not combine the best of two worlds and make the world of Game Demo Making a whole lot better by adding support for Opening / Exporting / Converting Counter-Strike Demos? (btw: This idea is not intended for just CS application...)
Please tell me if this has been done, if it can be done with a filter, a codec or something else. I'm not an expert on all of it, but it'd sure be cool.
Thanks much,
Mad_Martigan |
| Posted: Feb 11 2003, 05:00 AM |
Video game demos are typically done by either recording input or inputs to a particular subsystem of the game, such as the physics or render engine. They do not include the graphic resources and for the most part rendering the demo requires the entire game engine itself.
As an example, the DOOM .lmp file format stores only your input movements, including weapon switch, fire, and mouse movements. The file is useless by itself and in fact if DOOM's collision detection, AI, or physics routines are changed, or any of the level or item data changes, the demo becomes totally unplayable as it quickly desyncs from reality and the players start firing into walls. On the other hand, this is what allowed two hours of four-player mayhem to fit in ~120K. |
| Mad_Martigan |
| Posted: Feb 11 2003, 10:19 AM |
hmm, I think I understand what you're saying. Currently, the only way that I can watch the demos that I've made, is to open Counter-Strike and use the commands that come with the game. However:
Does this mean that you don't think it's possible? or It's just easier to use the game instead?
There is a program that attempts to make it easier to play / convert the demos, it's called GeekPlay. Sadly, I haven't figured it out yet. (Geekplay requires the game engine to be installed, which is what you're saying)
I also haven't figured out how to export at least the video to screen shots. Once it's to screenshots, I know that VirtualDub could handle and convert it to my hearts content. Maybe I need to do more research on demoing...?
Thanks for your time |
| muf |
| Posted: Feb 12 2003, 07:40 PM |
MCF team member
I once had a Quake 2 demo editor, that allowed saving to AVI. Forgot the name.
FYI: HL engine == slightly changed Q2 engine.
| BOB |
| Posted: Feb 12 2003, 09:56 PM |
| QUOTE (muf @ Feb 12 2003, 01:40 PM) | I once had a Quake 2 demo editor, that allowed saving to AVI. Forgot the name.
FYI: HL engine == slightly changed Q2 engine. |
FYI: HL engine == heavilly modified Quake 1 engine, its a common misconception that its based upon the Quake 2 engine.
BOB
| muf |
| Posted: Feb 13 2003, 11:17 AM |
MCF team member
| QUOTE (BOB @ Feb 12 2003, 03:56 PM) | | QUOTE (muf @ Feb 12 2003, 01:40 PM) | I once had a Quake 2 demo editor, that allowed saving to AVI. Forgot the name.
BOB |
FYI: Half-Life's engine is a hybrid between Quake 1, Quake 2 and valve's own code.
 FYI: Quale 2's engine is a heavily modified Quake 1 engine.
So in the end it's about the same as a slightly modified Quake 2 engine.
| Neo Neko |
| Posted: Feb 14 2003, 09:32 AM |
VirtualdubMod Alpha tester
The best solution would be for someone to code a mod for the game that would allow allow pre-recorded demos to be rendered frame by frame to the HD. Having said that you would loose all your hardware's T&L effects as Directx would have to be bypassed. Not to say that the HL engine or Counterstrike setup has much T&L support. Yech! Do people still regularly play that? |
| BOB |
| Posted: Feb 14 2003, 07:07 PM |
| QUOTE (muf @ Feb 13 2003, 05:17 AM) | FYI: Half-Life's engine is a hybrid between Quake 1, Quake 2 and valve's own code.
So in the end it's about the same as a slightly modified Quake 2 engine. |
Nope, its purely based on the Quake 1 source, not a single line of code from Quake 2 in it. As it would have cost much, much more $$$ in Sierra licensing the code from ID. Second, you only haveto look at the release dates of Quake 2 and Half-Life to see that no code from Quake 2 was used. Yes, I know that Quake 2 was based upon the Quake 1 codebase.. just like Quake 3 was based upon that codebase.
Neo Neko, there is a codec around that allows you to capture whats on screen to a avi file... I can't remember its name at this time, but if you've ever seen video files of ingame footage from games.. chances are they used that or a similar screen capture codec.
BOB |
| BOB |
| Posted: Feb 14 2003, 07:08 PM |
bwaha!
Found it, try http://www.fraps.com/ Neo Neko
BOB |
| Mad_Martigan |
| Posted: Feb 22 2003, 03:02 PM |
YAY!
Thanks for all the input... I downloaded fraps, now I just need to try it.
Thanks much!
Mad_Martigan |
