Command Line Video Editing
Skycryer
Posted: Jul 14 2010, 11:36 AM
Hope this is the right category i was not sure, ok ich have some videofiles here and i wish to join them.
They are divx, avi with mpeg4, dix or xvid codec. The one i wish to join are the same picture size, same framerate and same codec. (it was one video but was splitted sometime ago).
Can someone tell me is it possible to append/join this movie files from command line and how?
Please help me thx
Slowly
  Posted: Jul 14 2010, 03:39 PM
QUOTE (Skycryer @ Jul 14 2010, 11:36 AM)
Please help me thx
Dunno about the command line, but in the GUI it's trivial:
1. Open up VirtualDub
2. Open first video
3. File | Append AVI Segment...
4. Choose second video
5. Repeat Steps 3 and 4 until all files have been appended
6. Save As AVI...
7. Compress joined video with your favorite compressor if joined video is too big
Skycryer
Posted: Jul 15 2010, 10:33 AM
Yes i know it is trivial in the GUI but i need to make it with command line because of scripting, but thx for your help.
Posted: Jul 16 2010, 04:55 AM
Use VirtualDub.Append(), then do a VirtualDub.subset.Delete() at the end to reset the timeline.
Skycryer
Posted: Jul 16 2010, 07:19 AM
QUOTE (phaeron @ Jul 16 2010, 04:55 AM)
Is this a command line order? How to use it? Only goto Virtualdub folder and write virtualdub.append("file1.avi", "file2.avi", "file3.avi") but how can i give an output name for the full movie file?
Posted: Jul 16 2010, 10:07 AM
What you need to do is make a virtualdub script
Then in a .bat file you can use vdub.exe to run that script
All the command line options are in the help file
It's in the 'advanced operation' section
For making an example script, the easiest way is to
Load/append videos into virtualdub
File menu -> queue batch operation, save as avi
Then look at the VirtualDub.jobs file in virtualdub's folder
Here's an example one that just joins 2 avi's
VirtualDub.Open("K:\\NewVideos\\Film a-pt1.avi","",0);
VirtualDub.Append("K:\\NewVideos\\Film a-pt1.avi");
VirtualDub.audio.SetMode(0);
VirtualDub.audio.SetVolume();
VirtualDub.audio.EnableFilterGraph(0);
VirtualDub.video.SetInputFormat(15);
VirtualDub.video.SetOutputFormat(0);
VirtualDub.video.SetMode(0);
VirtualDub.video.SetPreserveEmptyFrames(0);
VirtualDub.video.SetIVTC(0, 0, 0, 0);
VirtualDub.video.SetCompression();
VirtualDub.project.ClearTextInfo();
 // -- $reloadstop --
VirtualDub.SaveAVI("H:\\Film a-joined.avi");
VirtualDub.Close();
The scripting language is on the docs page
http://www.virtualdub.org/virtualdub_docs.html
+ there's a bit hidden around the site somewhere about substituting file names with parameters to make life easier with a .bat file as well
Posted: Jul 16 2010, 11:22 AM
Just to clarify, you would use the /i parameter in a .bat file and add the file names
And in the script file you'd use VirtualDub.params[] to substitute the names
So in the script you'd have
VirtualDub.Open(VirtualDub.params[1],"",0);
VirtualDub.Append(VirtualDub.params[2]);
...any other commands you wanted
VirtualDub.SaveAVI(VirtualDub.params[3]);
And the .bat file would look like
vdub /i process.script "c:\part1.avi" "c:\part2.avi" "c:\joined.avi" /x
6 replies since Jul 14 2010, 11:36 AM Track this topic | Email this topic | Print this topic
