| burcs |
| Posted: Apr 9 2010, 07:39 AM |
After searching the forums I was surprised nobody had requested this. Maybe a lot of people weren't aware of it, as I only discovered it not too long ago myself. But I find it's invaluable for cutting out commercials and quickly adding the trims to my script. (In Vdubmod > Tools > scripts editor > import frameset as trims)
Another feature I wouldn't mind seeing added is the "Snapshot source frame/output frame", too.
http://i.imgur.com/B4r4B.png (highlighted)
Didn't use it a lot, just easier than setting in/out points around one frame, etc., or copying to clipboard then pasting in another app.
But with the scripts editor alone I could ditch Vdmod altogether. Thanks. |
| Posted: Apr 11 2010, 10:41 AM |
Sorry, but I'm afraid I don't have an interest in turning VirtualDub into a script editor for Avisynth.
As for the snapshot source/output frame function... details? Haven't used it myself. |
| burcs |
| Posted: Apr 14 2010, 08:05 AM |
The snapshot just gives you a direct save dialog, the snapshot output is highlighted in the screenshot in the previous post, or you can snapshot the source frame. Here's the dialog box.
http://i.imgur.com/Lfrtn.jpg
As for the scripts editor, as I said I haven't used it that long, but have found it pretty useful. I prefer x264 for most of my backups, which means using megui as the vfw x264 is a pain, or was last time I tried it. It's just handy for making cuts then adding them to the script, which I can then use with whatever encoder I need to, like TMPGenc or megui, etc.
http://i.imgur.com/FDvrh.jpg - editor
http://i.imgur.com/onmbG.jpg - import frameset as trims
http://i.imgur.com/nVDa1.jpg - result
Megui has an AVS cutter, too, but like the rest of the program it has horrible performance. Whereas with Vdubmod it's snip, snip, snip and I'm off. I can still use both programs so no biggie, it's just the only thing keeping me using Vdubmod. |
