| jcsston |
| Posted: Feb 6 2003, 02:51 AM |
Matroska Dev
Would it be possible to map the 'Capture AVI' File menu choice to a shortcut key?
The reason is I'm using VirtualDVR to automate my captures and it works by sending key-presses. It sends Alt-F to bring up the File menu but some times it fails and brings up the Filter dialog instead Ctrl-F which results in nothing being recorded
I wish I could compile VDub
| Belgabor |
| Posted: Feb 13 2003, 08:32 PM |
Developer of VirtualdubMod
Group: VirtualdubMod Team
Shameless plug: In vdubmod you can assign nearly any shortcut key to every menu item.
| jcsston |
| Posted: Feb 13 2003, 08:57 PM |
Matroska Dev
Thanks I've never used VirtualDubMOD for capture but I'll see how it goes
