| levicki |
| Posted: Jan 14 2010, 06:08 PM |
Avery,
I often invoke VirtualDub from the context menu option (right-click on file, Open in VirtualDub) which I added manually to the registry.
I also often open incomplete AVI files with missing index block.
I would appreciate having a way to specify on a command line that a file should be opened with "Re-derive keyframe flags" option enabled.
The way it is now, I have to open it and then open it again using extended options dialog (or browse to the file which is somewhere deep in the folder hierarchy).
Would you consider adding a switch or perhaps you have another suggestion on how to do it?
Oh, and it would be cool if that dialog showing (in my case pointless) warnings:
Could also be silenced from the command line. |
| squid_80 |
| Posted: Jan 15 2010, 03:43 AM |
You could script it. I think the open string with "Re-derive keyframe flags" enabled looks like this:
| CODE | VirtualDub.Open("file.avi","",0,"HAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAAHkAAA==");
But I think there's a chance it's version dependant... |
| Posted: Jan 15 2010, 04:44 AM |
That'll work for a while. I'll add the request to the feature request list. |
| levicki |
| Posted: Jan 15 2010, 07:06 PM |
| QUOTE (phaeron @ Jan 15 2010, 05:44 AM) | | That'll work for a while. I'll add the request to the feature request list. | Thanks Avery, script is not a solution because it requires injecting filename which would at least need a .BAT file and a temporary file for a script itself. |
| squid_80 |
| Posted: Jan 15 2010, 09:29 PM |
Use the /i switch and VirtualDub.params[0]. |
| levicki |
| Posted: Jan 16 2010, 05:57 PM |
| QUOTE (squid_80 @ Jan 15 2010, 10:29 PM) | | Use the /i switch and VirtualDub.params[0]. | Thanks, will try that, but that still won't disable the warning and its messy. |
| squid_80 |
| Posted: Jan 16 2010, 08:03 PM |
You could always make the changes and compile it yourself. |
| levicki |
| Posted: Feb 6 2010, 06:35 PM |
| QUOTE (squid_80 @ Jan 16 2010, 09:03 PM) | | You could always make the changes and compile it yourself. | Yes, and repeat those changes each time the new version of VirtualDub comes out. |
| levicki |
| Posted: May 29 2010, 12:06 PM |
Avery,
Is there any update on the status of this feature request? |
| Posted: May 30 2010, 04:17 AM |
Uh, sorry, no progress... I've been really busy at work and not really in much of a VirtualDub mood lately. |
