Pages: (3) 1 2 [3]  ( Go to first unread post )
Mpeg-2 Upgrade For Virtualdub, developers, come and get it!
dan2304k
Posted: Jan 26 2003, 05:13 AM
Probably need to play a 2 channel downmix during editing, but then just pass through the raw untouched ac3 frames when actually writing the AVI.
Alternatively a file->save ac3 would work just as well (for my purposes).
But yes, when I have an ac3 AVI, virtualdub can edit but can't play the audio. I usually select "no audio" while i'm working on the file and then switch it back to "direct stream copy" when I'm ready to save.
Thanks for considering my idea... working with HDTV is difficult at this point since it's such a new medium.
atavist
Posted: Jan 28 2003, 12:04 AM
QUOTE (dan2304k @ Jan 25 2003, 09:49 PM)
This is great work guys, but I would like to be able to to a *real* direct stream copy on ac3 audio.  I'm working with HDTV mpeg2 source, eventually making DVDs.  Since I'm going to DVD, I don't want a two channel downmix, I really want to be able to get the original ac3 audio.
Along the same lines, it would be useful to skip the step of converting the HDTV MPEG-2 source to an AVI for editing. How hard would it be to enable a direct stream copy of the MPEG-2 video, i.e., open the MPEG-2 source, edit cutting only on I-frames so you don't have to deal with re-encoding any frames, and then save the output back to an MPEG-2 program stream, rather than converting to AVI?
Even with HuffYUV, these intermediary AVIs are *large*.
Posted: Jan 28 2003, 12:56 AM
QUOTE (atavist @ Jan 27 2003, 08:04 PM)
How hard would it be ... ?
I think very.
It sounds to me like you HDTV guys are just looking for a simple way to edit your MPEG-2 streams losslessly. IMHO VirtualDub is not at all suited for this, and I think it would be far better to write a dedicated utility to edit MPEG without re-encoding. I was going to suggest TMPGEnc's cut/join tool, but then I seemed to remember it chokes on MPEG-2 input.
ChristianHJW
Posted: Jan 28 2003, 04:07 PM
QUOTE (fccHandler @ Jan 28 2003, 02:56 AM)
TMPEG's 'MPEG Tools' work fine on MPEG2 streams, however i dont find it half as convenient to use as vdub on AVIs.
I know some people here were questioning the sense of putting MPEG video streams into matroska files, but beleive me guys, MPEG container was not defined for editing at all, while this is matroska's biggest advantage.
As always, people are a little bit smiling about the 'hype' i make about matroska and the possibilities it will give us, being an open standard and very extensible with excellent backwards compatibility thanks to its EBML nature.
In the end, and i am 100% convinced about this, nobody will smile about it anymore once the first tools will be relased and people will start realizing what we can do with it ....
Posted: Jan 29 2003, 05:42 AM
QUOTE (ChristianHJW @ Jan 28 2003, 12:07 PM)
I have not had that experience at all, but I think it uses DirectShow, so it probably depends on what MPEG-2 filters you have installed.
Those "some people" include me, but it's not the "sense" that I'm questioning. Really I'm just doubting that it's possible to encapsulate MPEG content (with P and especially B frames) in a system that can be edited.
As always, people are a little bit smiling about the 'hype' i make about matroska ... In the end, and i am 100% convinced about this, nobody will smile about it anymore ....
I will smile if matroska succeeds, because I'll be so happy for you mate! biggrin.gif
ChristianHJW
Posted: Jan 29 2003, 06:53 AM
QUOTE (fcchandler @ Jan 29 2003,)
TMPEG is using DShow only for AVI import. The MPEG tools to cut/merge are not based on it.
matroska can handle all known frame types natively, and without needing 'dummy' frames as placeholders. frame order is encoding order (makes sense ).
And yes, i will smile too smile.gif !!
Posted: Feb 22 2003, 08:28 AM
huh.gif 8955 people have viewed this topic???
jcsston
Posted: Feb 22 2003, 09:05 AM
Matroska Dev
QUOTE (fccHandler @ Feb 22 2003, 02:28 AM)
Use the Matroska file format
37 replies since Jan 10 2003, 07:03 AM Track this topic | Email this topic | Print this topic
Pages: (3) 1 2 [3]
