Virtualdub 1.10.1 Released
Posted: Dec 24 2011, 08:56 PM
Downloadable at the usual place (http://virtualdub.sourceforge.net/). This version supercedes all 1.10.1 test releases.
Build 34703 (1.10.1, experimental): [December 23, 2011]
  [features added]
  * The "audio from other file" dialog now has an extended open options
    option.
  * Added m2a, m1a, and mpa as default supported extensions to the MPEG audio
    input module.
  * Added commands to cycle through files.
  * Added command to launch a new instance.
  * Added command to close and delete the current file.
  * Added auto-recover option.
  * Enhanced test videos with explicit YCbCr channel tests with markers for
    0-255 and 16-235 levels.
  * Audio filters dialog is now resizable.
  * AVI: File Information now displays audio format tag and prevents long
    video codec names from cutting off video tag.
  * Display: Added option for multi-monitor display acceleration.
  * Command line: Added /capaudiorec and /capaudioplay switches.
  * Command line: Added /resetall.
  * Command line: Added /portable to initialize portable settings mode.
  * Filters: Ported all remaining x86-only filters to x64.
  * Filters: Many internal filters are now marked as pure transforms to allow
    pass-through of duplicated frames.
  * Filters: Added support for BT.709 and full range formats to many video
    filters.
  * Filters: Video filters can now read from multiple input streams.
  * Filters: Video filters can now request zero source frames in a prefetch
    operation.
  * Filters: Logo filter no longer fetches source frames if the logo obscures
    the whole frame.
  * Filters: 3D acceleration mode prevents the display from going into
    power-saving mode.
  * Filters: 3D acceleration mode now uses Direct3D9Ex on Windows Vista/7 to
    run even with the display locked.
  * Filters: Improved error reporting when a 3D accelerated video filter
    fails due to a display mode switch.
  * Filters: Improved color space search rules for BT.709 and full range
    formats.
  * Filters: AVX support is now detected and reported to filters.
  * Codecs: Added About and Configure buttons to audio codec dialog.
  * UI: Fixed goofy multiple dialogs when selecting Other... in Video Depth
    dialog through the keyboard.
  * PluginAPI: Input drivers can now indicate when they have no external
    options dialogs.
  [bugs fixed]
  * Position control mark-in/out icons are now comctl32 v6 compatible.
  * Fixed mouse cursor vanishing when left-clicking while right-dragging the
    position nub.
  * Fixed .wav input handler using the wrong RIFF tag for signature
    detection.
  * Initial padding setting was being ignored for raw video input.
  * ExtEnc: Fixed extra data being written to audio pipe at end of stream.
  * ExtEnc: Removed WAVE64 padding from WAVE stream written to pipe to
    improve compatibility with marginal WAVE parsers.
  * ExtEnc: Fixed case where program would hang if the external encoder
    aborted early.
  * BatchWizard: Re-save as AVI and Extract to WAV functions now force the
    .avi and .wav extensions on output filenames.
  * Capture: "Windows Mixer" menu option now launches the Recording tab of
    the Sound control panel in Windows Vista and Windows 7.
  * Capture: Fixed weird disable wonkiness with the Position and Screen
    Height labels in the screen capture settings dialog.
  * Capture: Added option to allow selection of video codecs that do not
    support the current output format.
  * Capture: Fixed some frame skipping problems when conversions occured
    between filters with the filter chain enabled.
  * Capture: Fixed crashes when toggling black/white point extension with
    other capture filters active.
  * Capture: Volume meter and large timer settings are now saved.
  * Capture: Large timer is now erased at the end of capture.
  * Capture: Fix for a race condition related crash when changing capture
    size with preview acceleration enabled.
  * Command line: /capdevice no longer reselects a capture device if it is
    already the default.
  * Command line: Improved error reporting for /cmd switch.
  * Filters: Fixed bug in allocator merging code that was causing excessive
    memory usage when disparate frame sizes were used in the same filter
    chain.
  * Filters: Fixed some crashes in resize filter resulting from 0 size
    frames.
  * Filters: Fixed crash when sampling in the configuration dialog of a
    filter instance that has a blend curve attached.
  * Filters: Fixed box blur filter with MMX disabled.
  * Filters: The "save as default" button in the Resize filter was saving the
    settings from when the dialog was opened instead of the current settings.
  * Filters: Added additional protection against crashing out with abnormally
    large frames (>1M pixels on one side or >128MB pixels total).
  * Defaults: Default preview display depth is now 24-bit.
  * Defaults: DirectX hardware video overlays are now disabled by default to
    avoid color space issues and driver bugs.
  * Render: Added option to inhibit system sleep during renders (on by
    default).
  * Render: Added option for background I/O priority (Vista and up only).
  * Render: Fixed crashes in high quality audio sample rate conversion with
    very low or high rate values.
  * Audio: Added workaround for audio codecs that respond to decompression
    requests in acmFormatSuggest() but reject them in acmStreamOpen().
  * Audio: Compression dialog now reflects mono-left and mono-right
    conversion settings.
  * Video: Fixed crash with some codecs when bringing up video codec list
    (64-bit version only).
  * Display: Additional mode switch recovery fixes for Direct3D display mode.
  * Display: DirectDraw mode now works on Windows 8 developer preview.
  * Display: Direct3D9 mode now works on Windows 8 developer preview in
    software rendering mode (basic display driver).
  * Scripting: Empty statements are now allowed.
  * Images: Fixed crash when loading animated GIF without graphic control
    extension blocks.
anonymus.anonymus70
  Posted: Feb 29 2012, 06:30 PM
Crash-Info
VirtualDub crash report -- build 34676 (release)
Disassembly:
012d7060: 0000 add [eax], al
012d7062: 0000 add [eax], al
012d7064: 0000 add [eax], al
012d7066: 0000 add [eax], al
012d7068: 0000 add [eax], al
012d706a: 0000 add [eax], al
012d706c: 0000 add [eax], al
012d706e: 0000 add [eax], al
012d7070: 0000 add [eax], al
012d7072: 0000 add [eax], al
012d7074: 0000 add [eax], al
012d7076: 0000 add [eax], al
012d7078: 0000 add [eax], al
012d707a: 0000 add [eax], al
012d707c: 0000 add [eax], al
012d707e: 0000 add [eax], al
012d7080: 0000 add [eax], al
012d7082: 0000 add [eax], al
012d7084: 0000 add [eax], al
012d7086: 0000 add [eax], al
012d7088: 0000 add [eax], al
012d708a: 0000 add [eax], al
012d708c: 0000 add [eax], al
012d708e: 0000 add [eax], al
012d7090: 0000 add [eax], al
012d7092: 0000 add [eax], al
012d7094: 0000 add [eax], al
012d7096: 0000 add [eax], al
012d7098: 0000 add [eax], al
012d709a: 0000 add [eax], al
012d709c: 0000 add [eax], al
012d709e: 0000 add [eax], al
012d70a0: 0000 add [eax], al
012d70a2: 0000 add [eax], al
012d70a4: 0000 add [eax], al
012d70a6: 0000 add [eax], al
012d70a8: 0000 add [eax], al
012d70aa: 0000 add [eax], al
012d70ac: 0000 add [eax], al
012d70ae: 0000 add [eax], al
012d70b0: 0000 add [eax], al
012d70b2: 0000 add [eax], al
012d70b4: 0000 add [eax], al
012d70b6: 0000 add [eax], al
012d70b8: 0000 add [eax], al
012d70ba: 0000 add [eax], al
012d70bc: 0000 add [eax], al
012d70be: 0000 add [eax], al
012d70c0: 0000 add [eax], al
012d70c2: 0000 add [eax], al
012d70c4: 0000 add [eax], al
012d70c6: 0000 add [eax], al
012d70c8: 0000 add [eax], al
012d70ca: 0000 add [eax], al
012d70cc: 0000 add [eax], al
012d70ce: 0000 add [eax], al
012d70d0: 0000 add [eax], al
012d70d2: 0000 add [eax], al
012d70d4: 0000 add [eax], al
012d70d6: 0000 add [eax], al
012d70d8: 0000 add [eax], al
012d70da: 0000 add [eax], al
012d70dc: 0000 add [eax], al
012d70de: 0000 add [eax], al
012d70e0: 0000 add [eax], al
012d70e2: 0000 add [eax], al
012d70e4: 0000 add [eax], al
012d70e6: 0000 add [eax], al
012d70e8: 0000 add [eax], al
012d70ea: 0000 add [eax], al
012d70ec: 0000 add [eax], al
012d70ee: 0000 add [eax], al
012d70f0: 0000 add [eax], al
012d70f2: 0000 add [eax], al
012d70f4: 0000 add [eax], al <-- FAULT
012d70f6: 0000 add [eax], al
012d70f8: 0000 add [eax], al
012d70fa: 0000 add [eax], al
012d70fc: 0000 add [eax], al
012d70fe: 0000 add [eax], al
012d7100: 0000 add [eax], al
012d7102: 0000 add [eax], al
012d7104: 0000 add [eax], al
012d7106: 0000 add [eax], al
012d7108: 0000 add [eax], al
012d710a: 0000 add [eax], al
012d710c: 0000 add [eax], al
012d710e: 0000 add [eax], al
012d7110: 0000 add [eax], al
012d7112: 0000 add [eax], al
012d7114: 0000 add [eax], al
012d7116: 0000 add [eax], al
012d7118: 0000 add [eax], al
012d711a: 0000 add [eax], al
012d711c: 0000 add [eax], al
012d711e: 0000 add [eax], al
012d7120: 0000 add [eax], al
012d7122: 0000 add [eax], al
012d7124: 0000 add [eax], al
012d7126: 0000 add [eax], al
012d7128: 0000 add [eax], al
012d712a: 0000 add [eax], al
012d712c: 0000 add [eax], al
012d712e: 0000 add [eax], al
012d7130: 0000 add [eax], al
012d7132: 0000 add [eax], al
012d7134: 0000 add [eax], al
012d7136: 0000 add [eax], al
012d7138: 0000 add [eax], al
012d713a: 0000 add [eax], al
012d713c: 0000 add [eax], al
012d713e: 0000 add [eax], al
012d7140: 0000 add [eax], al
012d7142: 0000 add [eax], al
012d7144: 0000 add [eax], al
012d7146: 0000 add [eax], al
012d7148: 0000 add [eax], al
012d714a: 0000 add [eax], al
012d714c: 0000 add [eax], al
012d714e: 0000 add [eax], al
012d7150: 0000 add [eax], al
012d7152: 0000 add [eax], al
012d7154: 0000 add [eax], al
012d7156: 0000 add [eax], al
012d7158: 0000 add [eax], al
012d715a: 0000 add [eax], al
012d715c: 0000 add [eax], al
012d715e: 0000 add [eax], al
Built on Althena on Sun Oct 23 13:07:05 2011 using compiler version 1400
Windows 5.1 (Windows XP x86 build 2600) [Service Pack 3]
Memory status: virtual free 1971M/2048M, commit limit 3872M, physical total 1975M
EAX = 012d70f4
EBX = 0012f5c0
ECX = 00cc00a8
EDX = 00cbff68
EBP = 0000004e
ESI = 0012fb18
EDI = 0012f5c0
ESP = 0012f298
EIP = 012d70f4
EFLAGS = 00210202
FPUCW = ffff027f
FPUTW = ffffffff
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'VirtualDub'... ...reading address 012D70F4.
Pointer dumps:
EBX 0012f5c0: 001a0468 000003ff ffffff99 00000008 00000000 00000000 00000000 00000000
ECX 00cc00a8: 00cbff68 00000000 00614f68 0012f9b0 00cccf58 00cc50e8 00040003 010e0123
EDX 00cbff68: 00cc2870 012d70f4 012d70ec 00000000 00000000 00000000 0004001e 011401cb
ESI 0012fb18: 0064ca28 0012f9dc 0012f9dc 001a0468 00000000 00000001 02258948 02258980
EDI 0012f5c0: 001a0468 000003ff ffffff99 00000008 00000000 00000000 00000000 00000000
ESP 0012f298: 005a4a4a 003404bc 0012f5c0 0012f5c0 ffffffff 00000082 7e42c24e 7e42c291
0012f2b8: 003404bc 00000000 00000000 00000001 003404bc 005a2700 0012f308 7e419488
0012f2d8: 0012f3ac 00608a10 ffffffff 005a4e70 000003ff 0012f5c0 0012f9b0 005a27d3
0012f2f8: 000003ff 0012f5c0 003404bc 0012f9b0 005a2745 0000004e 000003ff 0012f5c0
Thread call stack:
005a4a4a: VDUIProxyListView::On_WM_NOTIFY()
7e42c24e: USER32!DefWindowProcA [7e410000+1c17e+d0]
7e42c291: USER32!DefWindowProcA [7e410000+1c17e+113]
7e419488: USER32!GetWindowLongA [7e410000+945d+2b]
005a4e70: VDUIProxyMessageDispatcherW32::Dispatch_WM_NOTIFY()
005a27d3: VDDialogFrameW32::DlgProc()
005a2745: VDDialogFrameW32::StaticDlgProc()
7e418734: USER32!GetDC [7e410000+86c7+6d]
7e423ce4: USER32!EnumDisplaySettingsA [7e410000+13a67+27d]
7e423b30: USER32!EnumDisplaySettingsA [7e410000+13a67+c9]
7e42b326: USER32!MoveWindow [7e410000+1b29e+88]
7e423d5c: USER32!DefDlgProcW [7e410000+13d3a+22]
7e418816: USER32!GetDC [7e410000+86c7+14f]
7e42927b: USER32!GetParent [7e410000+1910f+16c]
7e4292e3: USER32!SendMessageW [7e410000+1929a+49]
5d09682c: COMCTL32!InitCommonControls [5d090000+65cf+25d]
7e41882a: USER32!GetDC [7e410000+86c7+163]
7e428ea0: USER32!DefWindowProcW [7e410000+18d20+180]
7e428eab: USER32!DefWindowProcW [7e410000+18d20+18b]
5d0a07fa: COMCTL32!ImageList_Remove [5d090000+106df+11b]
5d0a1777: COMCTL32!DPA_DeleteAllPtrs [5d090000+11708+6f]
5d0a188f: COMCTL32!DPA_DeleteAllPtrs [5d090000+11708+187]
5d0a1a84: COMCTL32!DPA_DeleteAllPtrs [5d090000+11708+37c]
5d0a1a13: COMCTL32!DPA_DeleteAllPtrs [5d090000+11708+30b]
7e419491: USER32!GetWindowLongA [7e410000+945d+34]
7e42d3a9: USER32!DestroyMenu [7e410000+1d39d+c]
0042eb94: VDVideoFiltersDialog::OnDestroy()
005a27f1: VDDialogFrameW32::DlgProc()
7e428dd9: USER32!DefWindowProcW [7e410000+18d20+b9]
7e418bd9: USER32!GetWindowThreadProcessId [7e410000+8a80+159]
7e428dac: USER32!DefWindowProcW [7e410000+18d20+8c]
7e428d8b: USER32!DefWindowProcW [7e410000+18d20+6b]
7e429d09: USER32!SetRectEmpty [7e410000+19cba+4f]
7e423c0a: USER32!EnumDisplaySettingsA [7e410000+13a67+1a3]
7e42a505: USER32!PeekMessageA [7e410000+1a340+1c5]
7e428eec: USER32!DefWindowProcW [7e410000+18d20+1cc]
7c90e453: ntdll!KiUserCallbackDispatcher [7c900000+e440+13]
7e42b1a8: USER32!DestroyWindow [7e410000+1b19c+c]
7e42768f: USER32!CallMsgFilterW [7e410000+1750e+181]
7e4249c4: USER32!GetCursorFrameInfo [7e410000+147f8+1cc]
7e424a06: USER32!DialogBoxIndirectParamAorW [7e410000+149d0+36]
7e4247ea: USER32!DialogBoxParamW [7e410000+147ab+3f]
005a2c28: VDDialogFrameW32::ShowDialog()
00431c07: VDShowDialogVideoFilters()
00476186: VDProjectUI::SetVideoFiltersAsk()
7e42c2d0: USER32!SetWindowLongW [7e410000+1c2bb+15]
7ca2b1ce: SHELL32!DragAcceptFiles [7c9c0000+6b1a9+25]
0047d60d: VDProjectUI::MenuHit()
0047de49: VDProjectUI::MenuHit()
0048b610: VDUIFrame::DefProc()
0047ec57: _catch$?MainWndProc@VDProjectUI@@IAEJIIJ@Z$0()
00474dd0: VDProjectUI::WndProc()
0048bd15: VDUIFrame::StaticWndProc()
7e4189cd: USER32!GetWindowLongW [7e410000+88a6+127]
7e42a43b: USER32!PeekMessageA [7e410000+1a340+fb]
7e4196c7: USER32!DispatchMessageA [7e410000+96b8+f]
0045f9f6: WinMain@16()
005e42a6: __tmainCRTStartup()
7c817067: kernel32!RegisterWaitForInputIdle [7c800000+1701e+49]
-- End of report
Disassembly:
EAX = 012d70f4
EBX = 0012f5c0
ECX = 00cc00a8
EDX = 00cbff68
EBP = 0000004e
ESI = 0012fb18
EDI = 0012f5c0
ESP = 0012f298
EIP = 012d70f4
EFLAGS = 00210202
FPUCW = ffff027f
FPUTW = ffffffff
Crash context:
Pointer dumps:
Thread call stack:
-- End of report
This post has been edited by anonymus.anonymus70 on Feb 29 2012, 06:32 PM
evropej
Posted: Mar 1 2012, 02:41 AM
title in download page says its experimental still
Posted: Mar 3 2012, 04:21 AM
It is still experimental.
evropej
Posted: Mar 4 2012, 04:31 AM
pbristow
Posted: Oct 23 2012, 04:30 PM
I should check for updated versions more often, shouldn't I?
Yesss!! One of my long-term pet peeves that I didn't bother nagging about, as there were clearly bigger fish to be fried. Thanks for doing it anyway. biggrin.gif
5 replies since Dec 24 2011, 08:56 PM Track this topic | Email this topic | Print this topic
