| Altaf |
| Posted: Nov 13 2013, 04:19 PM |
2 вопроса к программистам: 1) Почему увеличивается мой ехе? Компилирую на Microsoft Visual Studio 2008, исходники конвертируются. Не поэтому? 2) Как сделать первые 4 опции взаимно исключающими в разделе "Source rate adjustment"? О чем написано выше. Я вряд ли найду ответ. Только время потрачу. Пожалуйста подскажите. +++++++ ++++++++ 2 questions to programmers: 1) Why mine increases ехе? I compile on Microsoft Visual Studio 2008, source codes are converted. Not therefore? 2) How to make the first 4 options mutually excluding in the section "Source rate adjustment"? About what it is written above. I hardly will find the answer. Only time I will spend. Please prompt.  2:23 14.11.2013 ехе файлы обновлены. Раздел "Частота кадров" изменил. ------------------------------------------------------------ 2:23 14.11.2013 ехе files are updated. The section "Frame Rate" changed. |
| meowmeow |
| Posted: Nov 14 2013, 01:58 AM |
| QUOTE (Altaf @ Nov 13 2013, 12:55 PM) | It should be 4 dependent options. When we put on one the second should not work!
Nope. May need adjustment and conversion at same time. One example: less frame count at same FPS (changing speed)
| QUOTE | | I compile on Microsoft Visual Studio 2008, source codes are converted |
That's one. VD better be compiled with 2005 so it can run on win'98.
Second, if you want smaller exe, 1) try to make "shared" exe which would need external dlls assuming users already has them in windows dirs or are easy to find. and or 2) try to find custom libraries to replace and hack VC. or 3) convert to and compile with Intel and or 4) write assembler code |
| meowmeow |
| Posted: Nov 14 2013, 02:03 AM |
This post has been edited by meowmeow on Nov 14 2013, 02:04 AM |
| Altaf |
| Posted: Nov 14 2013, 07:13 AM |
| QUOTE (meowmeow @ Nov 14 2013, 05:58 AM) | | QUOTE (Altaf @ Nov 13 2013, 12:55 PM) | It should be 4 dependent options. When we put on one the second should not work!
Second, if you want smaller exe, 1) try to make "shared" exe which would need external dlls assuming users already has them in windows dirs or are easy to find. and or 2) try to find custom libraries to replace and hack VC. or 3) convert to and compile with Intel and or 4) write assembler code | No, everything suits me. Simply, even the English version turns out more than from here (there few changes). I wanted to learn the reasons. |
| meowmeow |
| Posted: Nov 14 2013, 08:42 AM |
| QUOTE (Altaf @ Nov 14 2013, 07:13 AM) | | No, everything suits me. | No, I was hoping for something like that:
| Altaf |
| Posted: Nov 14 2013, 12:48 PM |
Я видимо не смог правильно перевести. 1) А какой смысл в этом? 2) Я чаще использую вторую опцию - "Change frame rate to (fps):", а кто-то другие. 3) "Note: Changing the framerate will cause audio/video desynchronization." - относиться только на "Change so video and audio durations match". ----------------------- I it is visible not I could to translate correctly. 1) And what sense in it? 2) I use the second option - "Change frame rate to (fps) more often: ", and someone others. 3) "Note: Changing the framerate will cause audio/video desynchronization. " - to belong only on "Change so video and audio durations match". |
| meowmeow |
| Posted: Nov 14 2013, 01:12 PM |
1) Adjustment and conversion separated from each other. 2) Ja ja, me too. 3) Yes, it belongs to whole adjustments options. 4) "Convert to ... fps, together with audio" is incorrect. Audio is not corrected in any way when you convert framerate. Frames dropped but delay between them also increases to keep sync. |
| Altaf |
| Posted: Nov 14 2013, 02:58 PM |
Как уже писал, меня свой вариант устраивает. Других мало кого волнует. Когда нужно, со звуком работаю на другой программе, после продолжаю в VD. Если нужно, я для Вас могу сделать свой вариант ехе с Вашим видом Frame Rate. Но, один раз. ------------------------------ As already I wrote, the option suits me. Very few people excite others. When it is necessary, with a sound I work at other program, the ambassador I continue in VD. If it is necessary, I for you can make the option ехе with your type of Frame Rate. But, once. |
| Altaf |
| Posted: Dec 2 2013, 04:26 PM |
Full sets together with mine -------------------------------------------------- Полные наборы вместе с моим ехе 1.10.5-test1 и 1.10.5-test1-AMD64 русс и 1.10.5-test1 и 1.10.5-test1-AMD64 eng |
| Altaf |
| Posted: Dec 5 2013, 10:05 AM |
I ask to prompt as to make so: https://cloud.mail.ru/public/3036fb80c7c9/VD.jpg In the right side below to place 2 (or one wide) strips. In top to submit information similar of "File information..." < "AVI Information" - "Length (frames). In bottom to give with the most right point of the toddler - given as a result to processing (all will be). ---------------------------------------- Прошу подсказать как сделать так: https://cloud.mail.ru/public/3036fb80c7c9/VD.jpg В правой стороне внизу разместить 2 (или одну широкую) полосы. В верхнем подавать информацию аналогичную из "Информация о файле" - "Длины (число кадров)". В нижнем подавать с самой правой точке ползунка - данные в результате обработке (всего будет). |
| meowmeow |
| Posted: Dec 7 2013, 12:58 AM |
| QUOTE | | kept profiles (3: 23.97600 ; 25.00000 ; 29.97000). I work only through them daily with many files. |
Yes, need fractions. Not zeros.
24000/1001~23.9760239760 better than 2997/125=23.976. Because frames*1001/24000 = time. Producing less fractions than frames*125/2997. And it's original, DVD&BD compatible. So do 30000/1001 etc. Good for GPU health too
There's many tools to check fps in avi files. Made by thousands every day, like avislisterx |
| Altaf |
| Posted: Dec 8 2013, 11:42 AM |
Now is shown so (23.97601; 25.00004 etc.). The made change remains (23.97600; 25.00000 etc.). Here try rus 1.10.4, 1.10.5 test 1, eng1.10.4, 1.10.5.1 test 1 |
| meowmeow |
| Posted: Dec 8 2013, 06:38 PM |
| QUOTE (Altaf @ Dec 8 2013, 11:42 AM) | | Here try rus , eng |
It doesn't works. Can't disable "convert to" feature combo button. And remove that "together with audio" note as audio didn't changes when convert frames. Add - "!!! warning: converting framerate damages your video so it cannot be repaired !!!"
Here's original VD with more framerate precision
How? find hex - replace to
252E3766 - 252E3966 252E3366 - 252E3966 252E3366 - 252E3966 252E3466 - 252E3966 |
| Altaf |
| Posted: Dec 9 2013, 01:47 AM |
meowmeow Personally that was necessary for me, I made completely. What is necessary for you? I likely don't understand. 1) I solved the problem arising at connection of several pieces of video. Often it is impossible, the program refuses because of different frequencies. And data are shown only - xx.xxx. And when I change them as I wrote above, everything connects. 2) When to have to watch data become so xx.xxxx. Now normal. |
| Altaf |
| Posted: Dec 18 2013, 10:27 AM |
| QUOTE (meowmeow @ Dec 8 2013, 10:38 PM) | | QUOTE (Altaf @ Dec 8 2013, 11:42 AM) | | Here try rus , eng |
I found a mistake and I remembered your message. And here my answer and gift: New_Year's_surprise, новогодное поздравление |
