| Altaf |
| Posted: Sep 9 2013, 05:19 PM |
New references: Delogo filter rus exe file (2:23 14.11.2013): eng With last changes: rus |
| Posted: Sep 9 2013, 06:42 PM |
What about it do you want testing?
| Altaf |
| Posted: Sep 10 2013, 03:29 AM |
Appearance. Convenient work. Faultless, exact management. Fatigue etc. |
| Posted: Sep 10 2013, 05:17 AM |
It seems fine, with very minimal changes from the original (icons for the buttons and position of the frame display text)
You'd have to give a list of what has changed so I know where to look
eg My own version (that's set up for my pc and assumes that various scripts are in certain places) https://dl.dropboxusercontent.com/u/1702491...DubModified.zip Some of the things to look at would be Frame information text -> larger text box, more information Job control dialog -> changed buttons and functions Job control dialog -> job priorities, if equal do compressed before lossless Job control dialog menu-> edit -> delete completed job source files, autodelete completed job source files Save dialog -> cleans filenames (_- etc), Main menu -> file menu -> processing defaults, lets you save and autoload settings at startup Main menu -> separate save menu -> save with codec and priority, save in parts Main menu -> video menu -> full processing mode (opens filters dialog auto), full processing mode (opens codec chooser) Main menu -> video menu -> Select codec directly (assumes you have the codecs installed) Main menu -> video menu -> prefer yuv Preferences dialog -> timeline page, more options for frame information Preferences dialog -> timeline page, more options for frame information Filters dialog -> double clicking filters in the list opens the config page, Filters -> extra filters - null autocrop, ivtc6, resize down Lower section of main window -> text for 'no audio', 'compressed audio' or opens the audio view when uncompressed audio Position slider -> bigger marker line, selection bar changes colour depending on codec, selection bar is brighter after a save/queue Curve editor -> ctrl+shift+click, clears all points Directshow file information settings -> extras tab, force filters (ffdshow, ac3filter, coreavc) Directshow file information settings -> prefer yuv/rgb
| Altaf |
| Posted: Sep 10 2013, 08:26 AM |
Thanks, it was pleasant to me. It is difficult to me to understand. Could not transfer in a source code? -------------------------------------------- 1) 3 - buttons and the gaps between some increased: - That during editing, when searching for the exact place to cut and paste, not to press by mistake not a button to not brushed away somewhere; - Stop as accurately as possible, quickly and without pushing past the stop button or a "dangerous" button. 2) The buttons are moved to the center - less and move quickly. 3) discolored, less visible - not to interfere, not to throw an eye.
The goal: When editing to find a place of cutting: - Move to the approximate location and click back and forth while looking at the pictures. For accurate account click on the 5, 6 buttons over and over again and I want quickly. And of course the mouse slowly away from the button, as luck would fall by 4 or 7 and jump. And to have to start again, look where it was and repeat. - Lose (2 button) and look at the video to watch out for the right place, trying to stop quickly, and do not get on the 1 th button. A slider has long been "passed."
You need to enter the gaps (like between the buttons 3 and 4, or between 11 and 12, but it is better to do these new spaces more) - Between the first and second; - The fourth and fifth; - The fifth and sixth; - The sixth and seventh. Buttons 1, 5 and 6 do a little larger,
Thus share and further allocates the most important, and often dramatically push. The place for it is enough. After all, the program is more convenient to work deploying more. -------------------------------------------
It would be desirable still
1) to the "Operating frequency of video frames" <"Set the frame rate" could put the value of a 5 th digit after the whole - eg, 23.97600 many people can not stick together because of this parameter does not match and it is to have a 4 - 5 th digit zero, otherwise the result is not obtained. And to show the actual setting up video too, just a 5-minute discharges after a whole.
2) There is a perfectly conceived tool - filter Conditional - Dmitri Shamshurko. But, it is very crude, ill see other filters, the main thing is not very stable. At any time during setup, closing filter Dab off and all that was done is lost. In fact, it would be handy to many. One is faced with the need to treat differently different parts of the video. That would be fine if his primary function to transfer or to introduce himself Vertual Dub.
Written in Borland C + + Builder. The filter itself, description, documentation and source code can be taken here: conditional There's also the author has consented to the use of all kinds.
In Daba loaded different filters is determined by their sequence, they are set up and is to limit or define their ranges (by length intervals video - bands, band). For existing probably need to add a separate button to filter, filter by zones. Load the next filter and push the button on (the zones and prescribes ranges). All the rest and so are available. Of course, the hidden work of programmers we do not see. But I think they will cope with such work. --------------------------------------------------- 3) View all customized settings to the video processing (as the presence of the loaded filters) and sound in one place, one-button mouse, or pointing? Another option would see the increase, decrease the volume. Or make to this option must be activated - set each file transfer (to option discharged).
When a lot of work and forced to interpose on any file change the volume, the next file is often forgotten, and this remains an option. More often remember when it is too late. Handled more files did not check (trust version) and deleted the source code. Although you can still adjust the volume. The same thing sometimes happens with video settings - codecs, filters happens. But many run multiple instances of the program and do different processing in parallel and in series. Not very surprising way to spoil forever. And if before starting the process can be easily seen that there had built, it would be fine. A "go" for this in different sections of the menu, to open different windows - a lot of time, effort, and as a consequence of consuming hunt.
4) The disadvantages are due to working with compressed audio. Well, when you edit a lot, decompress a few gigs, and then edit - it's a lost cause. Just say it with Avisentom process is in the preliminary decompression and therefore no error occurs. As far as I can tell, the decompression as if in memory or in a temporary file goes. Many people find it difficult to learn to work with Avisentom. If a Avisent expands, it is necessary to "teach" and most Vertual Daba also work without Avisenta? Not necessarily all the time. Rather probably do not need a constant, and can be [/ b] to ask for an option and that the process was in keeping with the parallel uncompressed audio. [/ B]
5) Set out on forum: Preservation The Chosen Type Of The Opened File |
| -vdub- |
| Posted: Sep 10 2013, 02:09 PM |
| QUOTE (http://translate.google.com/) |
Written in Borland C + + Builder. The filter itself, description, documentation and source code can be taken here: http://web.archive.org/web/20050306203350/...c1/conditional/ There's also the author has consented to the use of all kinds.
5) Set out on forum: http://forums.virtualdub.org/index.php?act...ST&f=15&t=21771 -------------------------------------------- | |
| Altaf |
| Posted: Nov 1 2013, 08:35 AM |
Дополнительно переведенный на русский exe и Delogo Фильтр Delogo русский. Фильтру с этим ехе файлом будет чуточку комфортнее.
Кто попробует тот поймет.
Там же мой английский exe файл. В exe переделал раздел < видео < "Частота кадров", думаю стал понятнее. Может поможет.
Жду замечании и предложения.
In addition translated into Russian exe и Delogo Filter Delogo Russian. To the filter with it ехе a file will be a little more comfortable.
Who will try that will understand.
In the same place my English exe a file. In exe has altered section "Video frame rate control", I think became more clear. Can will help.
I wait the remark and offers. |
| meowmeow |
| Posted: Nov 10 2013, 06:16 PM |
exe size 3152384 -> 4020736. meowmeow not impressed. |
| Posted: Nov 10 2013, 07:55 PM |
So? Do you buy cars by measuring the length?
One basic optimization technique trades off size for speed - faster code=larger size Also, extra code means it's almost certain to be bigger
And anyway It's a video editor........... Given that the files you deal with are much larger, it barely matters
| meowmeow |
| Posted: Nov 11 2013, 06:53 AM |
| QUOTE (dloneranger @ Nov 10 2013, 07:55 PM) | | faster code=larger size | Haha... Also the russian version is broken exactly the same way; it literally says in video/framerate menu - "note: changing the framerate will cause audio/video synchronization." |
| Posted: Nov 11 2013, 07:11 AM |
I'd pretty much expect it to It's phaerons source code just modified a bit and recompiled
Here's an idea, download it yourself then you can recompile it to make it smaller and correct any spelling
| Altaf |
| Posted: Nov 11 2013, 11:02 AM |
Спасибо, обратили внимание.
| QUOTE | Haha... Also the russian version is broken exactly the same way; it literally says in video/framerate menu - "note: changing the framerate will cause audio/video synchronization." |
Я не знаю программирование. Вынужденно взялся делать свой вариант. И в последнее время обратил внимание, что моя не сжатая версия большим получается. И что смог удалил. Указанная Вами опция и примечание не мои, в русской версии давно. Я с этой опцией не работал и не анализировал. Я изменил и передвинул в первую часть "Перевод в ___ кадр/сек, вместе с аудио". Именно эту опцию ищут некоторые. И к уменьшению частоту видео никак не относиться. Если бы приняли в обычную или показали, помогли исправить мою версию, буду очень рад и благодарен. ====================== I do not know programming. Forcedly undertook to do the variant. And recently has paid attention that my not compressed version big turns out. Also that the smog has removed. The option specified by you and the note not mine, in the Russian version for a long time. I with this option did not work and did not analyze. I have changed and have moved in the first part "Transfer in ___ a shot/sek, together with audio". This option is searched by some. And reduction frequency of video not to concern in any way. If have accepted in usual or have shown, have helped to correct my version, I will be very glad and grateful. New references: Delogo filter rusexe file eng With last changes: rus |
| meowmeow |
| Posted: Nov 13 2013, 04:52 AM |
| QUOTE (Altaf @ Nov 11 2013, 11:02 AM) | I have changed and have moved in the first part "Transfer in ___ a shot/sek, together with audio". This option is searched by some. |
I think that's abnormal program behavior
Besides, conversion must belong to conversion. When you adjust, only time changes, when convert - frames are dropped (or doubled)! |
| Altaf |
| Posted: Nov 13 2013, 12:55 PM |
| QUOTE (meowmeow @ Nov 13 2013, 08:52 AM) | |
Спасибо. Не возмущайтесь пожалуйста. Это должны быть 4 зависимые опции. Когда ставим на одно, то второе не должно работать! Сделаю если сумею. Может кто подскажет как сделать?
---------------------- Thanks. Be not indignant please. It should be 4 dependent options. When we put on one the second should not work! I will make if I will manage. Who can will prompt as to make?
| v0lt |
Posted: Nov 13 2013, 03:58 PM |
@Altaf Do not break the original interface! It is correct. |
