| vato76 |
| Posted: Jul 11 2009, 05:36 AM |
Excuse me, i have a question about how to install this. I assumed we are supposed to place the .vdplugin file into the virtualdub plugins32 folder, right? But where do i put the .cpp and .def files that are left in the archive? Thanks. |
| Jam One |
| Posted: Jul 11 2009, 07:26 AM |
-> Recycle bin. |
| lwc |
| Posted: Aug 19 2010, 09:26 AM |
Yes, those are the source code files. Anyway, the download link is dead. Luckily, people uploaded the plugin to temp hosts.
But is it supposed to work with v1.9.9?
I get this error message: |
| Jam One |
| Posted: Aug 19 2010, 02:15 PM |
1) Your error message does not have anything to do with MP4 Input Plugin. It is related to codecs.
2) I would suggest total switching to DirectShow Import Driver for all file types serviced by the third-party plugins earlier, except for MPEG2 Input Plugin.
I use DirectShow Import Driver very sucessfully for .mp4, .mov, flv, .ts, .mts, .m2ts files. I uninstalled the corresponding old plugins, and I feel quite happy about all that. Just remember to type extensions you need in DirectShow Import Driver's dialog properly - otherwise the driver won't grab the graph:
mp4 mov flv ts
and so on. No dots, no "stars" (ie NOT like "*.mp4"). |
| Graf |
| Posted: Mar 21 2014, 09:56 PM |
| QUOTE (Jam One @ Aug 19 2010, 02:15 PM) | | I would suggest total switching to DirectShow Import Driver for all file types serviced by the third-party plugins earlier |
can you tell how to do this? |
| Posted: Mar 21 2014, 11:33 PM |
You're a bit late posting to this one, it's 4 years old ;-)
For decoding non-avi files you use an input plugin from http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488
There are specific ones like the Quicktime plugin that's for mp4 and mov And there are also general purpose ones -> FFMpeg plugin -> DirectShow plugin
The specific ones can normally let you do direct stream copying if you need it, but need VFW and ACM codecs DirectShow - no direct stream copying, needs DirectShow codecs FFMpeg - no direct stream copying - needs no codecs at all
To use them you download the correct file - usually it's a .zip that you have to extract the contents from (You must use the same version as virtualdub, 32bit plugins for 32bit virtualdub and 64bit plugins for 64bit virtualdub) Then put the file(s) into virtualdub's plugins32 (32bit) or plugins64 (64bit) folder Start virtualdub Use the open video file dialog on the file menu Select the file you want to open, but before clicking OK, change the 'files of type' dropdown to the plugin you want to use, then click OK
FFMpeg plugin is the one that's probably your best bet, and on it's downloads page at sourceforge there's even an installer for people unfamiliar with .zip archives
| Graf |
| Posted: Apr 12 2014, 06:01 AM |
dloneranger, sorry for late post, when I try to open there some links, I see this message http://home.comcast.net/oops.gif
by the way, if I will download it, where I must place it? now I have a x86 version of VirtualDub, but I'm on x64 operating system |
| Posted: Apr 12 2014, 07:46 AM |
That's probably the original fcchandlers site then - there are mirrors of that also on the page, and in my sig
The bitness of the OS doesn't matter (apart from 32bit OS can't use 64bit programs) 32bit virtualdubs use the 32bit plugins and filters, and they go inside virtualdubs 'plugins32' folder (or 'plugins' for older virtualdubs) 64bit virtualdubs use the 64bit plugins and filters, and they go inside virtualdubs 'plugins64' folder (or 'plugins' for older virtualdubs)
To open files with a specific input plugin File menu->open video file Select file in dialog Change 'files of type' dropdown to the plugin you want (Check 'ask for extended options after this dialog' if you want to see the plugins options dialog before the video is loaded) Click 'open'
| Graf |
| Posted: Apr 12 2014, 09:46 AM |
dloneranger, I downloaded the last version of VirtualDub, added all needful plugins and codec WMV9 VCM, but he doesn't appear in compession section, when I add a wmv file, it says that "Missing codec", but older version of VirtualDub (1.5.4.1) has it and it works, I don't understand why... if there I can't add wmv and other plugins, can you tell, what I'm doing wrong? |
| Posted: Apr 12 2014, 11:31 AM |
That might not have the right codecs in for the wmv file - you need the right codec and also the same bit'ness as the version of virtualdub you're using (32bit codecs for 32bit programs etc) Virtualdub's file information dialog should give a code for the codec used, or MediaInfo can tell you what codecs etc a file uses http://mediaarea.net/en/MediaInfo/Download/Windows
I just use the ffmpeg plugin one for everything though as it generally "just works" wmv's in particular can be created in a way that causes trouble, with no seek indexing etc AsfBin can reindex these though http://www.radioactivepages.com/asfbin.aspx
| Graf |
| Posted: Apr 13 2014, 04:22 AM |
Forgot to say that I've downloaded x64 version of VirtualDub, cause I have a x64 system I know what codecs I need for VirtualDub, I'm familiar with that
Sorry, but maybe you haven't fully understood me, I don't need to create wmv's, I'm interested to convert from wmv (format and codec), mp4 (format) with H264 (codec) and others (don't like them for agressive using of CPU and are unreadable by most home DVD players) to avi (format) with XviD (codec)
Can you tell, what plugin I must use for webm format support by VirtualDub? I mean that he might see webm files, cause now he doesn't see them...
If I understand correctly AsfBin is a separate program, is not implemented in VirtualDub?
Also, I want to ask, for files with Windows Media Video 7/8 codecs I need another plugin in VirtualDub, Windows Media Video 9 codec support wouldn't handle them? |
| Posted: Apr 13 2014, 08:05 AM |
| QUOTE | | Forgot to say that I've downloaded x64 version of VirtualDub, cause I have a x64 system |
64 bit OS can run 64 bit programs and 32 bit programs ->64 bit programs need 64 bit codecs and plugins ->32 bit programs need 32 bit codecs and plugins wmv9vcm is 32 bit, so won't work in 64 bit programs
| QUOTE | Sorry, but maybe you haven't fully understood me, I don't need to create wmv's, I'm interested to convert from wmv (format and codec), mp4 (format) with H264 (codec) and others (don't like them for agressive using of CPU and are unreadable by most home DVD players) to avi (format) with XviD (codec) Can you tell, what plugin I must use for webm format support by VirtualDub? I mean that he might see webm files, cause now he doesn't see them... |
FFMpeg plugin
| QUOTE | | If I understand correctly AsfBin is a separate program, is not implemented in VirtualDub? |
Correct, it's a wmv fixer for troublesome files
| QUOTE | | for files with Windows Media Video... |
FFMpeg plugin
| Graf |
| Posted: Apr 13 2014, 09:44 AM |
| QUOTE | | wmv9vcm is 32 bit, so won't work in 64 bit programs |
so why the developers wouldn't make codecs and plugins for both version 32 bit and 64 bit, if it's the same program? or why developers of VirtualDub wouldn't make usable in 64 bit program codecs and plugins that was already made? then wouldn't be need to make codecs and plugins for every version (32 bit and 64 bit) of programs
hope it's the right FFMpeg plugin link for VirtualDub what you mean, if not, please, give the right link, initially I confused it with ffdshow
can you tell, where did dissapear Streams section from menu in last version of VirtualDub? I want to use Video comments section, maybe you know, when in AviInfo it's wrote Created by: VirtualDubMod... the last version of VirtualDub don't write there anything
by the way, how to resolve this problem?:
this is detailed info of the file:
but don't tell me that is missing some codec, cause I'm already converted a file with the same parameters, I've already installed DivX WMA Audio Compressor and in audio compression section have Lame MP3 and MPEG Layer-3 codecs for convert
| Posted: Apr 13 2014, 12:42 PM |
| QUOTE | | why developers of VirtualDub wouldn't make usable in 64 bit program codecs and plugins that was already made? then wouldn't be need to make codecs and plugins for every version (32 bit and 64 bit) of programs |
Brilliant idea Now figure out how to do it, and let microsoft know, you'll make loads of money
| QUOTE | | where did dissapear Streams section from menu in last version of VirtualDub |
Virtualdub has NEVER had a streams menu VirtualdubMOD did, but that was a modified version of virtualdub made by someone else, who stopped supporting it
| QUOTE | | I want to use Video comments section, maybe you know, when in AviInfo it's wrote Created by: VirtualDubMod... the last version of VirtualDub don't write there anything |
File menu->set text information
| QUOTE | | by the way, how to resolve this problem? |
That's an error in your source file, it's damaged and the codec can't decode it -that divx one is a particularly lame/old/hacked version of microsofts one Chop that bit out, use a different plugin/codec that may ignore the error, or select a different error mode from the audio menu
The link for the FFMPeg virtualdub plugin (not ffmpeg the program) is in my sig, look down a bit from here and it's right there Also available from the long list of plugins here-> Links to Virtualdub Filters and Input Plugins
| Graf |
| Posted: Apr 13 2014, 03:04 PM |
| QUOTE | | Now figure out how to do it |
where do I know, the developers must know, they created it for ex. some programs are made universally for both 32 bit and 64 bit systems
| QUOTE | | and let microsoft know |
why microsoft must know about this?
| QUOTE | | File menu->set text information |
more precisely, please, there are lot of lines, where concretely to write?
| QUOTE | | That's an error in your source file, it's damaged and the codec can't decode it |
MediaCoder decoded it successfully, but I don't like the quality what result after decoding, so I prefer VirtualDub
| QUOTE | | use a different plugin/codec that may ignore the error |
for ex. what different codec? I don't know what codec for decoding it used now
| QUOTE | | select a different error mode from the audio menu |
I tried, no effect
thanks for the lnik, find there a lot of amazing filters A long list of all sort of filters, which I'm about to install by pack, hope they will be useful
offtop. why here doesn't work all BBCode Buttons? just some of them works |
