| Mr Hangman |
| Posted: Jan 18 2012, 05:39 PM |
I realized the issue might have been the audio, but even after remembering to check "No Audio" I am still unable to get past the "No video codec is selected" error. That's on an H264 file, now using the recommended x264vfw codec. |
| AEN007 |
| Posted: Jan 26 2012, 03:57 PM |
26January2012
any feedback/response regarding my previous MSUSD/avs/FastRe/FullProc/crash posts? |
| AEN007 |
| Posted: Feb 1 2012, 09:05 AM |
1February2012
Greetings.
I have seem to have stumbled upon the source/cause of the MSUSD/avs crashes. I hope ViDub dev might/will find a fix. So far I have not been able to find a work-around solution.
Yesterday I did/dubbed a YT flv file. This YT flv file is not one of those 480x? files. For the time being I have abandoned those & the 320x240 files I would DSC IF the source quality was not unacceptable, which I find it to be.
Anyway, I am using the YT flv 640x480 files. These seem to be the highest quality sources to redub. Almost all of them have 29.970 fps; however, yesterday one of them had 23.976. I (now) always set ViDub to convert the fps to 23.976 - even if the source is already @ 23.976 ... see the following»| QUOTE (AEN007 @ Jan 8 2010, 08:59 AM) | 8January2010
Greetings.
What I described below is still happening when I use aviSynth input. I can't leave the setting at Process all frames. I have to set a frame rate value.
Any helpful insights/replied appreciated. Thank you. Regards, AEN Æ
| QUOTE (AEN007 @ Dec 6 2008, 10:52 PM) | 6Dec2008 I suppose the 160mb output result might be related to a new problem I've encountered with VDub. I always set the frame rate to "change so video & audio durations match". (I always export/improve the original audio & then use my new wave file as the source audio for the encoding.) The problem I've encountered is that SOMETIMES when I leave the frame rate conversion setting at "Process all frames", the resulting avi output file is encoded incorrectly & comes out super huge. Has anybody else encountered this issue? I would of course like to hear from anyone who knows more than me about this issue. I don't know why this output encoding error occurs SOMETIMES when I leave the frame rate conversion setting at "Process all frames". If I then redo the encoding & set the "Convert to fps" to 29.97 or 25.000 or whatever, the resulting output is problem free. |
Anyway, ViDub did NOT crash upon completing a modified batch for this 23.976fps file. It seems that setting ViDub to convert the fps is causing these MSUSD/avs crashes. Settting ViDub to convert from 23.976 to 23.976 did not cause an MSUSD/avs crash.
ViDub does not end with an MSUSD/avs crash if I do not set ViDub to convert from 29.970 or 25 to 23.976. ViDub does end with an MSUSD/avs crash when I use aviSynth AssumeFPS or ConverFPS - whether or not I also set ViDub to Process all frames or to convert ...
I hope ViDub dev might/will find a fix. I'll be trying to find a work around. Any helpful replies/insights appreciated. Thank you. Regards. AEN Æ |
| AEN007 |
| Posted: Feb 1 2012, 01:32 PM |
1February2012
Greetings.
I emailed MSU about this avs/MSU/fps issue. Then I found the/ir Deblocking plugin @ their website. This MSUDeB plugin does NOT cause these avs/MSU/fps crashes, so ...
My other "open" items in this thread remain.
What is the best/proper procedure for using (Smart) Deblocking with avs? Is it best to do the modified batch anyway? e.g., not load/use the MSU plugin until the final/nth pass by using separate avs scripts?
What about Fast recompress versus Full processing? This might only be relevant to the passes in a modified batch that do not load/use the MSU plugin. It seems (based on the fps @ which ViDub runs) that loading/using the MSU plugin makes ViDub automatically run in FullP ...
(I also emailed MSU about the MSUDeB plugin results ...) |
| AEN007 |
| Posted: Mar 18 2012, 01:30 AM |
| QUOTE (AEN007 @ Jan 8 2012, 03:17 PM) | | Is there some/place/way to register to be notified of fcchandler updates? | maybe the following thread»fcchandler? |
