| Pral |
| Posted: Dec 18 2014, 05:27 AM |
Hi sorry if this question has already been asked. I used virtual dub earlier this year and it was working fine. But I've had to restore my computer and started from new. Now I'm not sure what filters I'm missing but I'm unable to open mp4 files, I installed quicktime, and ffdshow now I'm able to open the video file but I only get sound and no picture. I'm not sure what I'm doing wrong? Would someone be kind enough to enlighten me please? If I opened this thread in the wrong forum my apologies. I hope someone can help me out. Thanks in advance. |
| Posted: Dec 18 2014, 05:39 AM |
Is the screen just black? If so check the display options, turn off all the direct* things and see if it works, then turn back on until you find the one causing it
| Pral |
| Posted: Dec 18 2014, 05:48 AM |
Thank you for trying to help out, really appreciate it.
The screen is green...before that I couldnt open it at all, I kept getting "Missing codec AVC1" so I installed ffdshow now the file opens but the screen stays green.
I tried choosing full instead of direct as you suggested but it's not helping |
| Posted: Dec 18 2014, 05:57 AM |
Sorry, I meant the display options in the preferences On the menu Options->preferences Left hand side, select Display Untick all the 'use DirectX(3D)' Click ok until the preferences close
See if that helps
| Pral |
| Posted: Dec 18 2014, 06:08 AM |
That didnt help either I used the same files I saved into a folder so I dont know what else I'm missing. Maybe it's a codec for media files? Also I couldnt open up the files at all until I installed quicktime player for the computer as well. It wouldnt open up until I installed the player because I thought that might help |
| Posted: Dec 18 2014, 06:17 AM |
There are 2 quicktime plugins - IIRC in the one that needs quicktime there's a setting (tick extended options when opening a file) that should be set to 2 (or 3?) for it to work, I seem to recall it gives a green screen otherwise
fccHandlers is the newest one http://forums.virtualdub.org/index.php?act...=ST&f=7&t=19488 If there's a 'no codec' message, check FFDShow's vfw configuration dialog and tick any required codecs
There are also plugins that handle nearly everything (but don't do direct stream copy) like the FFMPeg plugin in my sig
| Pral |
| Posted: Dec 18 2014, 07:11 AM |
Thank you so much! I'll try it out tomorrow and let you know if it works. I don't quite get the extended options when opening the file though |
| Posted: Dec 18 2014, 09:42 AM |
On the file menu, open a video, and on the dialog that shows the file name, tick the box for extended options. The plug in options should be shown after you pick a file
| Pral |
| Posted: Dec 21 2014, 07:49 PM |
I havent a chance to work on this, would you tell me exactly what plugin I need? Sorry it looks all too confusing for me. Some of the links labelled fcchandlers that is temporarily disabled when you try to click on it |
| Posted: Dec 21 2014, 08:03 PM |
If you don't need direct stream copy, I'd just use the FFMpeg plugin at it loads almost everything (link is in my sig) If you need direct stream copy, then fcchandler quicktime plugin (link to fcchandlers plugins are in my sig as well)
----- On the page with the full list of plugins, it's worth reading everything there, as the first lines say that fcchandlers original page is offline, and mirrors are posted at the bottom
| Pral |
| Posted: Dec 21 2014, 08:19 PM |
Thank you! I need the direct stream option, so if i need to open up mp4 files, which option would I pick? the mp2 plugin? |
| Pral |
| Posted: Dec 21 2014, 08:24 PM |
OMG thank you soooo much! I downloaded the quicktime plugin you linked me to and it worked!!!!!!!!!!!! Thanks so much for all your help and patience |
| Pral |
| Posted: Dec 21 2014, 08:25 PM |
| QUOTE | | If you need direct stream copy, then fcchandler quicktime plugin (link to fcchandlers plugins are in my sig as well) |
| Pral |
| Posted: Dec 21 2014, 09:54 PM |
Thank you for all your assistance. Really appreciate it |
