| i4004 |
| Posted: Jul 24 2007, 07:51 PM |
he's bored and wants vdub-mpeg2 1.7.x....
| neuron2 |
| Posted: Jul 24 2007, 09:43 PM |
| i4004 |
| Posted: Jul 25 2007, 03:20 AM |
DGMPGDec is too hard to use. too complex.
loading mpeg to vdub-mpeg2 is straightforward....
i myself don't mind the indexing portion of dgmpgdec(in the end, vdub-mpeg2 takes time to load mpeg too...), but splitting video from audio(in order to process it) is rather unnatural to somebody who's accustomed to avisource()...or vdub users. would be easier if vdub could load mp2...
hm..but it seems vdubmod indeed can load mp2 audio. well...timing couldn't be better; i just have a big .ts file that needs compression....now dgmpgdec is easier to use...
| Posted: Jul 25 2007, 07:58 AM |
Once VirtualDub 1.7.x is declared stable, I will release VirtualDub-MPEG2 1.7.x. It might even be able to import MPEG Layer II as a separate stream. Wait and see.
| i4004 |
| Posted: Jul 25 2007, 01:31 PM |
acm mp2 codec can be found here http://briefcase.yahoo.com/bc/timltaylor/l...rc=bc%26.view=l (search for "QDesign_CoDec ", add '.exe' on the end upon saving)
| squid_80 |
| Posted: Jul 25 2007, 01:53 PM |
Or from the sticky in the codecs forum: http://www.geocities.com/wilbertdijkhof/qmpeg_mp2.zip |
| blob2500 |
| Posted: Aug 28 2007, 12:09 PM |
Hi! In Virtualdub-mpeg2 (with file avi with mp3 audio loaded): Audio Direct Stream Copy selected, Menu File->Save Wav chosing mpeg audio (.mpa, .mp2, .mp3) in menu, the file out it's not a real mp3 file but it's an actual wav file container (the header of file is a RIFF/WAV) with incorrect .mp3 extension. This type of file is already present with its correct exstension ".wav" in saving menu option. It's a bug? I think it isn't correct.. Thank you.. and thanks FccHandler for the development of your program
(excuse me for my english..) |
| foxidrive |
| Posted: Aug 28 2007, 12:56 PM |
Is it a VCD file? In VeeDub threads it is mentioned that the mp2 audio in MPEG files has to be decoded to a WAV because of timing issues, but this may not apply here. |
| blob2500 |
| Posted: Aug 28 2007, 01:15 PM |
No, it's not a vcd file. Each avi file with mp3 audio..
The correct extension of audio file pcm in wav or mp3 in wav is ".wav", no ".mpa/.mp3"
".mp3" (or generic .mpa) extension is correct if mp3 audio is not into wav container.
PCM into wav container -> .WAV extension is correct (option present in vdub-mpeg2 option) MP3 into wav container -> .WAV extension is correct (option present in vdub-mpeg2 option) MP3 into wav container -> .MPA/.MP3 extension is not correct! (option present in vdub-mpeg2 option) MP3 into native mpa container -> .MPA/.MP3 extension are correct (option not present in vdub-mpeg2 option)
| Posted: Aug 28 2007, 06:20 PM |
It's a bug. The output of "Save WAV" is always a RIFF/WAVE file, regardless of the extension. Those other extensions are for importing audio files, and they shouldn't appear in that dialog. Thanks for pointing it out.
| yawnmoth |
| Posted: Aug 30 2007, 04:51 AM |
| QUOTE (neuron2 @ Jul 24 2007, 09:43 PM) | Oh, I see, he was being cute.
I don't know why people don't just use DGMPGDec to decode and serve into plain vanilla VirtualDub. They get the power of Avisynth that way too. | DGMPGDec requires you make a *.d2v file, which is just as - if not more time-consuming - then letting VirtualDub MPEG-2 parse the MPEG2 file, itself.
I don't know about you, but I, personally, prefer it when the video I want to load loads instantaneously, just as *.avi's do.
Anyway, on the subject of VirtualDub-MPEG2... if I open a few *.vob's, one after the other, VirtualDub-MPEG2 usually crashes. No idea why. Is this a known problem? |
| neuron2 |
| Posted: Aug 30 2007, 05:55 AM |
| Posted: Aug 30 2007, 06:00 AM |
| QUOTE (yawnmoth @ Aug 30 2007, 12:51 AM) | | ... if I open a few *.vob's, one after the other, VirtualDub-MPEG2 usually crashes. No idea why. Is this a known problem? | Nope, I've never heard of that problem. If it crashes again, please follow the instructions and save a crash report, then post the full contents here.
| yawnmoth |
| Posted: Oct 9 2007, 04:35 AM |
| QUOTE (fccHandler @ Aug 30 2007, 06:00 AM) | | QUOTE (yawnmoth @ Aug 30 2007, 12:51 AM) | | ... if I open a few *.vob's, one after the other, VirtualDub-MPEG2 usually crashes. No idea why. Is this a known problem? |
Nope, I've never heard of that problem. If it crashes again, please follow the instructions and save a crash report, then post the full contents here. |
The problem I described earlier doesn't manifest itself all the time, however, today, it did (I'm still using 1.6.15 - I didn't know a new version had been released).
Here's the crashinfo.txt file:
| CODE | VirtualDub-MPEG2 crash report -- build 24600 (release) --------------------------------------
Disassembly: 004fd680: 56 push esi 004fd681: 33c0 xor eax, eax 004fd683: 51 push ecx 004fd684: 8b7114 mov esi, [ecx+14h] 004fd687: 8b5110 mov edx, [ecx+10h] 004fd68a: 837c240c00 cmp dword ptr [esp+0ch], 00h 004fd68f: 7e2f jle 004fd6c0 (VDMPEGDecoder::show_bits+40) 004fd691: 837c240c18 cmp dword ptr [esp+0ch], 18h 004fd696: 7f28 jg 004fd6c0 (VDMPEGDecoder::show_bits+40) 004fd698: 2bd6 sub edx, esi 004fd69a: 7e24 jle 004fd6c0 (VDMPEGDecoder::show_bits+40) 004fd69c: c1ee03 shr esi, 03h 004fd69f: 03710c add esi, [ecx+0ch] 004fd6a2: 83fa18 cmp edx, 18h 004fd6a5: 7e1e jle 004fd6c5 (VDMPEGDecoder::show_bits+45) 004fd6a7: 8b06 mov eax, [esi] 004fd6a9: 0fc8 bswap eax 004fd6ab: 8b4914 mov ecx, [ecx+14h] 004fd6ae: ba20000000 mov edx, 00000020 004fd6b3: 2b54240c sub edx, [esp+0ch] 004fd6b7: 83e107 and ecx, 07h 004fd6ba: d3e0 shl eax, cl 004fd6bc: 8aca mov cl, dl 004fd6be: d3e8 shr eax, cl 004fd6c0: 59 pop ecx 004fd6c1: 5e pop esi 004fd6c2: c20400 ret 0004 004fd6c5: 83fa10 cmp edx, 10h 004fd6c8: 7e0b jle 004fd6d5 (VDMPEGDecoder::show_bits+55) 004fd6ca: 8a4602 mov al, [esi+02h] 004fd6cd: c1e010 shl eax, 10h 004fd6d0: 668b06 mov ax, [esi] 004fd6d3: ebd4 jmp 004fd6a9 (VDMPEGDecoder::show_bits+29) 004fd6d5: 83fa08 cmp edx, 08h 004fd6d8: 7e05 jle 004fd6df (VDMPEGDecoder::show_bits+5f) 004fd6da: 668b06 mov ax, [esi] 004fd6dd: ebca jmp 004fd6a9 (VDMPEGDecoder::show_bits+29) 004fd6df: 85d2 test edx, edx 004fd6e1: 7ec6 jle 004fd6a9 (VDMPEGDecoder::show_bits+29) 004fd6e3: 8a06 mov al, [esi] 004fd6e5: ebc2 jmp 004fd6a9 (VDMPEGDecoder::show_bits+29) 004fd6e7: 90 nop 004fd6e8: 90 nop 004fd6e9: 90 nop 004fd6ea: 90 nop 004fd6eb: 90 nop 004fd6ec: 90 nop 004fd6ed: 90 nop 004fd6ee: 90 nop 004fd6ef: 90 nop 004fd6f0: 56 push esi 004fd6f1: 33c0 xor eax, eax 004fd6f3: 51 push ecx 004fd6f4: 8b7114 mov esi, [ecx+14h] 004fd6f7: 8b5110 mov edx, [ecx+10h] 004fd6fa: 837c240c00 cmp dword ptr [esp+0ch], 00h 004fd6ff: 7e36 jle 004fd737 (VDMPEGDecoder::get_bits+47) 004fd701: 837c240c18 cmp dword ptr [esp+0ch], 18h 004fd706: 7f2f jg 004fd737 (VDMPEGDecoder::get_bits+47) 004fd708: 2bd6 sub edx, esi 004fd70a: 7e2b jle 004fd737 (VDMPEGDecoder::get_bits+47) 004fd70c: c1ee03 shr esi, 03h 004fd70f: 03710c add esi, [ecx+0ch] 004fd712: 83fa18 cmp edx, 18h 004fd715: 7e25 jle 004fd73c (VDMPEGDecoder::get_bits+4c) 004fd717: 8b06 mov eax, [esi] <-- FAULT 004fd719: 0fc8 bswap eax 004fd71b: 8b74240c mov esi, [esp+0ch] 004fd71f: 8b5114 mov edx, [ecx+14h] 004fd722: 017114 add [ecx+14h], esi 004fd725: 8bca mov ecx, edx 004fd727: ba20000000 mov edx, 00000020 004fd72c: 2bd6 sub edx, esi 004fd72e: 83e107 and ecx, 07h 004fd731: d3e0 shl eax, cl 004fd733: 8aca mov cl, dl 004fd735: d3e8 shr eax, cl 004fd737: 59 pop ecx 004fd738: 5e pop esi 004fd739: c20400 ret 0004 004fd73c: 83fa10 cmp edx, 10h 004fd73f: 7e0b jle 004fd74c (VDMPEGDecoder::get_bits+5c) 004fd741: 8a4602 mov al, [esi+02h] 004fd744: c1e010 shl eax, 10h 004fd747: 668b06 mov ax, [esi] 004fd74a: ebcd jmp 004fd719 (VDMPEGDecoder::get_bits+29) 004fd74c: 83fa08 cmp edx, 08h 004fd74f: 7e05 jle 004fd756 (VDMPEGDecoder::get_bits+66) 004fd751: 668b06 mov ax, [esi] 004fd754: ebc3 jmp 004fd719 (VDMPEGDecoder::get_bits+29) 004fd756: 85d2 test edx, edx 004fd758: 7ebf jle 004fd719 (VDMPEGDecoder::get_bits+29) 004fd75a: 8a06 mov al, [esi] 004fd75c: ebbb jmp 004fd719 (VDMPEGDecoder::get_bits+29) 004fd75e: 90 nop 004fd75f: 90 nop 004fd760: 56 push esi 004fd761: 8bf1 mov esi, ecx 004fd763: 8b4614 mov eax, [esi+14h] 004fd766: 8bc8 mov ecx, eax 004fd768: f7d9 neg ecx 004fd76a: 83e107 and ecx, 07h 004fd76d: 03c1 add eax, ecx 004fd76f: 8b4e10 mov ecx, [esi+10h] 004fd772: 3bc1 cmp eax, ecx 004fd774: 894614 mov [esi+14h], eax 004fd777: 732c jnc 004fd7a5 (VDMPEGDecoder::next_start_code+45) 004fd779: 6a08 push 08h 004fd77b: 8bce mov ecx, esi 004fd77d: e8 db 0e8h 004fd77e: 6e outsb 004fd77f: ff db 0ffh
Built on Mike on Fri Jul 07 02:07:44 2006 using compiler version 1200
Windows 5.1 (Windows XP build 2600) [Service Pack 2]
EAX = 00000000 EBX = 00000000 ECX = 00ba4008 EDX = 0002d5f8 EBP = 00ba4008 ESI = 00001ad4 EDI = 00000002 ESP = 0012fb18 EIP = 004fd717 EFLAGS = 00210202 FPUCW = ffff027f FPUTW = ffffffff
Crash context: An out-of-bounds memory access (access violation) occurred in module 'VirtualDub'...
...reading address 00001AD4.
Pointer dumps:
ECX 00ba4008: 00565e10 00000001 02920000 00001ad4 0002d5f8 00000000 0b0a0808 110f0e0d ESP 0012fb18: 00ba4008 00ba4008 004fd782 00000008 00000001 004fdb87 0287e910 00ba4008 0012fb38: 0287e920 00006e8f 004538ce 00001ad4 00005abf 00006e90 00000001 00000002 0012fb58: 00000001 0012fbe8 00545808 00adf9c0 0012fbe0 00b847e0 00498eb6 00000000 0012fb78: ffffffff 00006e90 00000000 00000000 00000000 00adf9c0 ffffffff ffffffff EBP 00ba4008: 00565e10 00000001 02920000 00001ad4 0002d5f8 00000000 0b0a0808 110f0e0d 00ba4028: 0c0b0808 13110f0e 0e0d0b0a 1311110f 0e0d0b0b 1413110f 0f0e0d0b 18141210 00ba4048: 100f0e0d 1d181412 110f0e0d 231c1713 13120f0e 2a231c17 0a090908 0c0b0b0a 00ba4068: 0a0a0909 0c0c0b0b 0b0a0a09 0d0c0c0b 0b0b0a0a 0e0d0c0c 0c0b0b0a 0e0e0d0d
Thread call stack: 004fd717: VDMPEGDecoder::get_bits() 004fd782: VDMPEGDecoder::next_start_code() 004fdb87: VDMPEGDecoder::DecodeFrame() 004538ce: VideoSourceMPEG::streamGetFrame() 00498eb6: VDProject::UpdateFrame() 00409e7c: FrameSubset::lookupFrame() 00498a29: VDProject::DisplayFrame() 00498a29: VDProject::DisplayFrame() 00467d7c: VDPositionControlW32::SetPosition() 0049ab2e: VDProject::MoveToNext() 0049ab2e: VDProject::MoveToNext() 0049dbfb: VDProjectUI::MenuHit() 7e419488: USER32!GetWindowLongA [7e410000+945d+2b] 7e41b3a7: USER32!DefWindowProcW [7e410000+b33c+6b] 004a6ca1: VDUIFrame::DefProc() 0049f54b: VDProjectUI::MainWndProc() 7e41b3a7: USER32!DefWindowProcW [7e410000+b33c+6b] 7e419488: USER32!GetWindowLongA [7e410000+945d+2b] 7e41b3a7: USER32!DefWindowProcW [7e410000+b33c+6b] 004a6ca1: VDUIFrame::DefProc() 7e419488: USER32!GetWindowLongA [7e410000+945d+2b] 0049f0fe: VDProjectUI::WndProc() 004a6f64: VDUIFrame::StaticWndProc() 7e418734: USER32!GetDC [7e410000+86c7+6d] 7e418816: USER32!GetDC [7e410000+86c7+14f] 7e41b4c0: USER32!DefWindowProcW [7e410000+b33c+184] 7e41b50c: USER32!DefWindowProcW [7e410000+b33c+1d0] 7c90eae3: ntdll!KiUserCallbackDispatcher [7c900000+ead0+13] 7e42fac7: USER32!TranslateAccelerator [7e410000+1fa84+43] 7e42fae4: USER32!TranslateAccelerator [7e410000+1fa84+60] 004a6e09: VDUIFrame::TranslateAcceleratorMessage() 0048db5d: WinMain@16() 005288df: WinMainCRTStartup() 7c816fd7: kernel32!RegisterWaitForInputIdle [7c800000+16f8e+49]
-- End of report |
I had opened a *.vob and was trying to extract select scenes from it by hitting Shift + left / right arrow and then incrementing / decrementing by individual frames to get the most frame selection possible so that I could delete it.
edit: here's what the Windows XP Crash Report thing said:
| CODE | <?xml version="1.0" encoding="UTF-16"?> <DATABASE> <EXE NAME="VirtualDub.exe" FILTER="GRABMI_FILTER_PRIVACY"> <MATCHING_FILE NAME="auxsetup.exe" SIZE="16384" CHECKSUM="0xFDA87627" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1.4" FILE_DESCRIPTION="VirtualDub Setup Utility" COMPANY_NAME=" " PRODUCT_NAME="VirtualDub" FILE_VERSION="1.4" ORIGINAL_FILENAME="Setup.exe" INTERNAL_NAME="Setup" LEGAL_COPYRIGHT="Copyright © 1998-2001 Avery Lee, All Rights Reserved" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="05/28/2006 22:07:59" UPTO_LINK_DATE="05/28/2006 22:07:59" VER_LANGUAGE="English (United States) [0x409]" /> <MATCHING_FILE NAME="vdicmdrv.dll" SIZE="6656" CHECKSUM="0x1D2D9626" BIN_FILE_VERSION="1.0.0.1" BIN_PRODUCT_VERSION="1.0.0.1" PRODUCT_VERSION="1.3" FILE_DESCRIPTION="VirtualDub installable video compressor/decompressor" COMPANY_NAME=" " PRODUCT_NAME="VirtualDub" FILE_VERSION="1.3" ORIGINAL_FILENAME="vdicmdrv.dll" INTERNAL_NAME="vdicmdrv" LEGAL_COPYRIGHT="Copyright © 1998-2000 Avery Lee, All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.0.0.1" UPTO_BIN_PRODUCT_VERSION="1.0.0.1" LINK_DATE="05/28/2006 22:07:51" UPTO_LINK_DATE="05/28/2006 22:07:51" VER_LANGUAGE="English (United States) [0x409]" /> <MATCHING_FILE NAME="vdremote.dll" SIZE="7168" CHECKSUM="0x9C8DCAB8" BIN_FILE_VERSION="1.5.10.1" BIN_PRODUCT_VERSION="1.5.10.1" PRODUCT_VERSION="1.5.10-sp1" FILE_DESCRIPTION="AVIFile-to-VirtualDub-Frameserver glue library" COMPANY_NAME=" " PRODUCT_NAME="VirtualDub" FILE_VERSION="1.5.10-sp1" ORIGINAL_FILENAME="vdremote.dll" INTERNAL_NAME="vdremote" LEGAL_COPYRIGHT="Copyright © 1998-2004 Avery Lee, All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.10.1" UPTO_BIN_PRODUCT_VERSION="1.5.10.1" LINK_DATE="05/28/2006 22:07:55" UPTO_LINK_DATE="05/28/2006 22:07:55" VER_LANGUAGE="English (United States) [0x409]" /> <MATCHING_FILE NAME="vdsvrlnk.dll" SIZE="5120" CHECKSUM="0xF1AB3F62" BIN_FILE_VERSION="1.5.10.1" BIN_PRODUCT_VERSION="1.5.10.1" PRODUCT_VERSION="1.5.10-sp1" FILE_DESCRIPTION="VirtualDub server communication library" COMPANY_NAME=" " PRODUCT_NAME="VirtualDub" FILE_VERSION="1.5.10-sp1" ORIGINAL_FILENAME="vdsvrlnk.dll" INTERNAL_NAME="vdsvrlnk" LEGAL_COPYRIGHT="Copyright © 1998-2004 Avery Lee, All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.5.10.1" UPTO_BIN_PRODUCT_VERSION="1.5.10.1" LINK_DATE="05/28/2006 22:07:53" UPTO_LINK_DATE="05/28/2006 22:07:53" VER_LANGUAGE="English (United States) [0x409]" /> <MATCHING_FILE NAME="vdub.exe" SIZE="7738" CHECKSUM="0xB6EE2BD5" BIN_FILE_VERSION="1.6.5.0" BIN_PRODUCT_VERSION="1.6.5.0" PRODUCT_VERSION="1.6.5" FILE_DESCRIPTION="VirtualDub command-line driver application" COMPANY_NAME=" " PRODUCT_NAME="VirtualDub" FILE_VERSION="1.6.5" ORIGINAL_FILENAME="vdub.exe" INTERNAL_NAME="VirtualDub" LEGAL_COPYRIGHT="Copyright © 2005 Avery Lee" VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.6.5.0" UPTO_BIN_PRODUCT_VERSION="1.6.5.0" LINK_DATE="05/28/2006 22:08:51" UPTO_LINK_DATE="05/28/2006 22:08:51" VER_LANGUAGE="English (United States) [0x409]" /> <MATCHING_FILE NAME="VirtualDub.exe" SIZE="776704" CHECKSUM="0xD43BDBD" BIN_FILE_VERSION="1.6.15.0" BIN_PRODUCT_VERSION="1.6.15.0" PRODUCT_VERSION="1.6.15" FILE_DESCRIPTION="VirtualDub" COMPANY_NAME="" PRODUCT_NAME="VirtualDub-MPEG2" FILE_VERSION="1.6.15" ORIGINAL_FILENAME="VirtualDub.exe" INTERNAL_NAME="VirtualDub" LEGAL_COPYRIGHT="Copyright © 1998-2006 by Avery Lee, All Rights Reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x1" MODULE_TYPE="WIN32" PE_CHECKSUM="0x0" LINKER_VERSION="0x0" UPTO_BIN_FILE_VERSION="1.6.15.0" UPTO_BIN_PRODUCT_VERSION="1.6.15.0" LINK_DATE="07/07/2006 06:07:44" UPTO_LINK_DATE="07/07/2006 06:07:44" VER_LANGUAGE="English (United States) [0x409]" /> </EXE> <EXE NAME="kernel32.dll" FILTER="GRABMI_FILTER_THISFILEONLY"> <MATCHING_FILE NAME="kernel32.dll" SIZE="984576" CHECKSUM="0xF0B331F6" BIN_FILE_VERSION="5.1.2600.3119" BIN_PRODUCT_VERSION="5.1.2600.3119" PRODUCT_VERSION="5.1.2600.3119" FILE_DESCRIPTION="Windows NT BASE API Client DLL" COMPANY_NAME="Microsoft Corporation" PRODUCT_NAME="Microsoft® Windows® Operating System" FILE_VERSION="5.1.2600.3119 (xpsp_sp2_gdr.070416-1301)" ORIGINAL_FILENAME="kernel32" INTERNAL_NAME="kernel32" LEGAL_COPYRIGHT="© Microsoft Corporation. All rights reserved." VERFILEDATEHI="0x0" VERFILEDATELO="0x0" VERFILEOS="0x40004" VERFILETYPE="0x2" MODULE_TYPE="WIN32" PE_CHECKSUM="0xF9293" LINKER_VERSION="0x50001" UPTO_BIN_FILE_VERSION="5.1.2600.3119" UPTO_BIN_PRODUCT_VERSION="5.1.2600.3119" LINK_DATE="04/16/2007 15:52:53" UPTO_LINK_DATE="04/16/2007 15:52:53" VER_LANGUAGE="English (United States) [0x409]" /> </EXE> </DATABASE> | |
| Posted: Oct 9 2007, 05:41 AM |
Thanks for the crash log. It's very strange that it crashed in "get_bits()", because that is a function which is called thousands of times for every MPEG that anyone has ever opened in VirtualDub-MPEG2...
My recommendation is to get the latest version. There was at least one rare MPEG crash situation which was fixed in a later update. If the latest version of VirtualDub-MPEG2 1.6.19 crashes with the same .vob file, please post the crashlog from that.
