Virtualdub 1.6.8 (23567)
Posted: Jul 4 2005, 12:24 AM
Build 23567 (1.6.8, stable): [July 3, 2005]
  [bugs fixed]
  * Fixed occasional crash if display panes are refreshed while editing the
    filter list.
  * Fixed hang if VirtualDub is the active application and attempts to refresh
    the display panes when a display mode switch occurs.
  * Display panes did not always update properly when seeking if Direct3D mode
    was enabled and updating the frame took a lot of CPU time.
  * Direct3D display mode could be activated if checked even if the option was
    grayed due to DirectX support being disabled.
  * Capture: Fixed crash if capture is attempted with audio enabled but audio
    isn't present or is in an incompatible format.
  * Reversed direction of mouse wheel action to be consistent with Windows.
  * Hex editor's Extract Segment command would sometimes extract the wrong
    segment due to repainting the main pane during the extract.
  * CLI interface app didn't exit if console was empty prior to invocation due
    to overzealous Explorer detection. This is now only done if no arguments
    are supplied.
  * Fixed crash in MPEG-1 parser when encountering a pack with a too-short
    length, such as zero.
  * Audio codec errors sometimes reported the wrong source of the error (i.e.
    decompressor vs. compressor).
  [regressions fixed]
  * Pixel shaders were disabled in Direct3D bicubic mode due to debug code
    mistakenly left in.
  * MRU list sometimes didn't resort properly when reopening a recently opened
    file.
Posted: Jul 4 2005, 05:37 AM
It doesn't look like you addressed my silly gripe, but that's OK. You know I'm going to mod it anyway. tongue.gif
(In all honesty, I'm getting used to the new slider behavior so it's not much of an issue anymore.)
Thank you for your great work!
meilin
Posted: Jul 4 2005, 05:48 AM
BTW:
Darkfalz
Posted: Jul 4 2005, 04:57 PM
It's the stable version now eh? Maybe I'll finally upgrade from 1.5.10
i4004
Posted: Jul 4 2005, 09:48 PM
hihihihi...hitler.
my signature:
Posted: Jul 5 2005, 04:14 AM
I should mention that the source code for 1.6.8 isn't linked on the SourceForge page.
Posted: Jul 5 2005, 04:23 AM
Hmm? Don't know what you're talking about. (closes psftp)
Posted: Jul 5 2005, 04:25 AM
Darkfalz
Posted: Jul 5 2005, 09:00 AM
Just wondering, is it possible for 1.5.10 and a 1.6.x version to peacefully co-exist on the system? Or will one interfere with the settings of the other in the registry?
i4004
Posted: Jul 5 2005, 03:44 PM
all versions go to same registry entry, but i would still say they can coexist.
i have 1410,1510 and 165 "installed".
165 to cap, 1510 to load mpeg2 (very rarely though) and 1410 for most other work (editing etc.)
didn't experience much problems.....except that capping defaults to last dir used (by 1410 for example) and not the default cap dir i set.
my signature:
Posted: Jul 6 2005, 03:30 AM
Some of the saved settings have switched locations in the Registry between 1.5 and 1.6, so some of the settings you save in one version may not propagate to the other, but otherwise there shouldn't be a problem. I regularly run versions as old as 1.4 from my archives in order to track down regressions.
KornX
  Posted: Jul 7 2005, 02:46 PM
would it be possible to save the performance options???
ah yah and i am sitting here and trying to develop some simple C progs
(part of becoming an engineer in Germany)
and i hate it, so be sure to be admired for ur work...
KornX
There are only 10 types of people;
Those who do and those who don't understand binary.
KornX
Posted: Jul 8 2005, 04:32 PM
ah yah and would it be possible to have in the filter input cropping a scaler? (like 8:1,4:1,2:1/1:1/1:2,1:4,1:8)
for people with a screenres < videosize
(e.g. hdtv video cropping with my 1280x1024 screen is impossible...)
KornX
Posted: Jul 9 2005, 04:19 AM
Good idea, but I'm afraid it will have to wait until 1.7.
KornX
  Posted: Jul 9 2005, 09:19 AM
both features???
by the way, i seems to me it makes no big difference, if the performance options are changed???
has sb tested this and could tell us???
KornX
16 replies since Jul 4 2005, 12:24 AM Track this topic | Email this topic | Print this topic
Pages: (2) [1] 2
