| psolord |
Posted: Jan 15 2015, 02:01 PM |
Hello.
I have virtualdub 1.10.5 32bit, on my Windows 7 X64 machine and I use it to convert fraps files to avis.
I use H264 codec for video and Lame MP3 for Windows for Audio.
Everything works fine.
Now the trouble started when I enlisted my Windows 8.1 X64 machine to do the same job.
I copied the whole virtualdub folder, installed H264 codec through its installation program and the same for Lame MP3.
Unfortunately, I do not get any options in the audio compression setting as illustrated by the picture below.
What am I missing my good friends? |
| Posted: Jan 15 2015, 02:27 PM |
Well, you're missing the Lame codec completely - that could be the problem It should be listed as Lame MP3
Lame MP3 works fine in Win8.1, but from Vista onwards any of the .bat installers have to be run as an administrator (right click on the .bat and run as administrator) This has been such a headache for people that I put all the files in an installer that will install 64 and 32bit versions as required It's in my sig just below this message if you want it
| -vdub- |
| Posted: Jan 16 2015, 10:58 AM |
For those installers choose link below. That will open a browser tab/window sourceforge.net where you can download these installers
SetupAC3acm_X86_X64.zip SetupLameMp3acm_X86_X64.zip SetupAACacm_X86_X64.zip |
