Decode Xvid Videos?, Is it possible to decode my videos?
blackleafdragon
Posted: Feb 27 2015, 03:03 PM
Hey there, im kinda new to compressing with virtualdub.
I have compressed some fraps videos to the xvid codec, making them alot smaller.
However my sony vegas appareantly really dislike those encoded videos for live preview render smile.gif
But i have already deleted my original fraps file D: is it possible to decode my video with virtualdub?
Posted: Feb 27 2015, 05:40 PM
If you did the compression with VirtualDub, then you should also be able to do the decompression with it.
If not, then just download and install the Xvid-codec, before opening the video with VirtualDub.
You can find it here: https://www.xvid.com/download/
To decompress to "uncompressed AVI" (or to another video-codec instead of Xvid):
- Open the AVI-file in VirtualDub
- In the Video-menu, select "Full processing"
- In the Video-menu, click "Compression..." and verify if the selection is set to the first option: (uncompressed RGB/YCbCr),
or select a codec to re-compress to an other format than Xvid
- Click OK
- Now, save the AVI to a new one, via File > Save as AVI...
1 replies since Feb 27 2015, 03:03 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
