Vd Crash Opening X264vwf Encoded Avi
nzero1
Posted: Feb 15 2015, 03:03 PM
VirtualDub crashes when opening avi file with video previously encoded with x264vfw (H264) also using VD.
x264vfw is installed from the latest release r2525bm.
Same crash from VD 1.10.4 to 1.10.5 beta 7
part of VirtualDub crash report -- build 35560 (release)
Disassembly:
03fb823f: 50 push eax
03fb8240: ff91b4000000 call dword ptr [ecx+b4] <-- FAULT
03fb8246: 8bf0 mov esi, eax
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'ffdshow'...
...reading address E8F18C0A...
...while querying video codec with FOURCC "ffds" (w32videocodec.cpp:440)...
...while attempting codec negotiation: fccHandler=0x00000000, biCompression=0x34363248 (w32videocodec.cpp:531).
-- End of report
Thank you for suggestions
-vdub-
Posted: Feb 15 2015, 03:52 PM
I don't use ffdshow atm other alternatives that may help you
Update ffdshow
OR
Open the video using a different decoder such as
Fcchandlers Quicktime (fcchanlder) (for x264 .mp4 videos)
http://sourceforge.net/projects/fcchandler/files/
Also get the AacAcm Codec to decode video with aac audio. Also there is Ac3Acm for ac3 audio in video
These below will load and decode x264 .avi videos
FFMpeg input driver (dloneranger)
http://sourceforge.net/projects/virtualdub...peginputplugin/
FFmpeg Caching Input Driver (Shekh)
http://sourceforge.net/projects/vdcachingdriver/
nzero1
Posted: Feb 15 2015, 05:34 PM
Yes, it seems to work with VD 1.10.5 beta 7 + Caching Input Driver (Shekh) only (15-jan-2015 release).
Audio synchro with video seems OK too for my ts recorded files (PVR DVB-T), but I cannot cut out of keyframes, so I will use VD 1.10.5 beta 5 + FF input driver 0.8.1.7 first.
Posted: Feb 15 2015, 06:21 PM
Easiest way to keep working as you're used to is to just disable the h264 codec in ffdshows 'vfw config' panel
Then virtualdub should use x264vfw codec instead
nzero1
Posted: Feb 15 2015, 08:16 PM
I don't know how to disable the H264 codec in the x264vfw config panel.
I have tried many options, but all have failed.
I can open one avi file with "VD 1.10.5 beta 7 + Caching Input Driver" but I cannot append another avi segment, and direct stream copy in unsuccessful: "compression not compatible with avi".
shekh
Posted: Feb 15 2015, 09:10 PM
QUOTE (nzero1 @ Feb 15 2015, 08:16 PM)
Sorry, full processing only.
If you want to open multiple segments you can rename files to file.00.avi, file.01.avi, ... and check "automatically load linked segments" in the file dialog.
Posted: Feb 15 2015, 09:36 PM
It's FFDShows codec that's crashing not x264vfw, so it's the FFDShow one that need disabling
On your start menu/screen there should be a VFW configuration entry, from that you'd look for the H264 entry and change it to disabled
There is another FFDShow video dialog and an audio one, you can leave those alone it's just the VFW one that needs changing
-vdub-
Posted: Feb 16 2015, 11:20 PM
QUOTE (nzero1 @ Feb 15 2015, 05:34 PM)
If you cannot figure how to correct ffdshow or until have time to work ffdshow settings and options out. You could always rename the ffdshow plugin (ffvdub.vdf) in the virtualdub plugins folder
Cut using I frames or cut other frames including I frames
Direct copy allows only cutting on I frames
Other modes allow for cutting IPB frame
More info for the modes there is Virtualdub Help
Virtualdub - (Keyboard Select F1)
Menu - Help Contents
Virtualdub (folder) help file - Virtualdub.chm
Posted: Feb 17 2015, 12:09 AM
it's not a plugin in virtualdubs folder thats crashing, it's the ffdshow codec itself - removing the plugin will not stop the crash
-vdub-
Posted: Feb 17 2015, 04:37 PM
If I see what your saying fourcc in registry shows ffdshow is available for use based on highest merit value or the one to use. I thought if ffdshow plugin was unavailable the registry would look to the next fourcc available highest merit value or best choice codec to use. This is based on XP OS other microsoft OS may be different !
nzero1 Is this the ffdshow version you have installed and using ? if not what ffdshow version are you using !
If time is not on your side and need to complete the video processing. If unable to disable ffdshow or you still have problems when disable ffdshow. Uninstall remove ffdshow I would do next if the above rename plugin didn't work. Use virtualdub plugins for now until you have time to test other ffdshow versions using the same video file your having problems with now
For further help it would be helpful to link or make to a small start clip of your video then upload it using a free to download open file share site. Others here using ffdshow and/or virtualdub plugins can take a further look at this. HJSplit and other tools can be used to split in to a video clip for uploading. It can be done using virtualdub also http://forums.virtualdub.org/index.php?act...=ST&f=4&t=21591 other tools maybe a lot easier to split with
nzero1
Posted: Feb 28 2015, 04:06 PM
Many codec packages were installed on my computer over time.
After a mistake today to badly update ffshow from Matroska readme link with an older version, I have reinstall first Matroska Pack Full v1.1.2, and after x264vfw_full_41_2525bm_41092.
Now files such as http://www.partage-fichiers.com/upload/1dx7f3gg can be open in VD, and reprocessed.
Thank you all for your replies.
ale5000
Posted: Feb 28 2015, 04:55 PM
You have misunderstood, you crash has nothing to do with x264vfw or Matroska.
It is the H264 decoding inside ffdshow VFW that is crashing.
If you disable H264 decoding inside the ffdshow VFW codec then VirtualDub will use the other codec x264vfw to decode.
If you leave H264 decoding enabled inside the ffdshow VFW then x264vfw won't be used also if it is installed correctly.
New VirtualDub forum
11 replies since Feb 15 2015, 03:03 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
