| ale5000 |
| Posted: Mar 3 2015, 01:19 AM |
Hi, I'm just reporting a thread that I have found, they talk about the latest stable version of VirtualDub.
| QUOTE | | vdub 1.10.4 ... The rec.709 options on the "other" dialog don't work at all |
Ref: http://forum.videohelp.com/threads/366469-...-best-for-input
| shekh |
| Posted: Mar 3 2015, 10:12 AM |
Not sure what is there in the thread, but here are few my observations: Input colorspace in VD does matter.
I have bt.709 full range mp4 sources - these have colorspace tags. If I feed from my input driver untouched YUV and specify colorspace as bt.709 full range (as reported by ffmpeg), the picture is right.
If I remux the same source to avi with ffmpeg tool, I have to use "alias format" filter which brings missing colorspace info. I have not figured but it seems like avi does not support colorspaces at all. Then the picture is identical.
If I recompress it (full processing from rgb) to x264, and set bt709 and full range options in x264 options dialog, on the output I have identical avi (with quantization like 10 only few pixels differ by 1 bit). I still need to set "alias format" but thats ok for avi.
So, for me everything works well. |
| ale5000 |
| Posted: Mar 3 2015, 01:19 PM |
I think they talk about converting from rec.601 to rec.709 using VirtualDub itself (not codecs or input plugins).
| shekh |
| Posted: Mar 3 2015, 01:25 PM |
In my example VirtualDub is converting from YUV to RGB. At least here I dont see problem. |
