Closing Virtualdub when dialogs are open
ale5000
Posted: Feb 26 2015, 01:54 PM
[mod note: split from test5 thread]
There is a peculiar bug:
If I send PostMessage(winHwnd, WM_CLOSE, 0, 0) to VirtualDub when it is on the "VirtualDub Program Failure" windows it open the "VirtualDub Program Failure - Detail" window instead of exiting; instead sending it to the "VirtualDub Program Failure - Detail" actually crash the crash handler.
New VirtualDub forum
Posted: Feb 26 2015, 03:40 PM
It's not a bug, you're sending a close message to virtualdub when it's got a modal dialog open
Normally this does not happen eg open the filters list and try clicking on virtualdubs close button
You could rewrite the code in the projectui.cpp message handler for wm_close to shut down extra windows, or as that's probably doomed to failure (as you'd have to cover all possible open dialog windows) enumerate down the list of dialogs that virtualdub has open and close them from the bottom up (some dialogs have their own ones as well)
ale5000
Posted: Feb 26 2015, 05:04 PM
Regarding the crash, maybe then it is better to ignore WM_CLOSE in situations where it can't be easily done (open dialog windows) instead of this random behaviour.
shekh
Posted: Feb 26 2015, 05:15 PM
Why are you sending the message?
I am not sure but probably WM_CLOSE is not leagal message for a disabled window.
If you begin sending random messages everything will crash.
ale5000
Posted: Feb 26 2015, 06:48 PM
Just a last explanation.
I send WM_CLOSE from an external program because I need VirtualDub closed.
It would be nice if it close if it can or not close if it can't but it would be nice if it isn't crash or open window with WM_CLOSE.
Posted: Feb 26 2015, 08:04 PM
Well, you can start virtualdub with the /h switch which will disable the crash reporting dialog
But... you'll still get the windows error reporting one (unless you've disabled that)
But really the best way to do it, is to do it properly
http://support.microsoft.com/kb/178893
So, you find virtualdubs window, enum it to find any top level children windows, recurse until you've found the last one and close them from the bottom up
When you're emulating a person then you have to do it how it can be done
eg
you physically can not click the close button of virtualdub when a modal dialog is open
why doest windows let you do this?
because it's to stop users doing just what you've tried and having their programs crash in mysterious ways
ale5000
Posted: Feb 26 2015, 11:13 PM
Thanks for the help but I'm doing an installer for VirtualDub, that detect if it is active and close it, it is not opened by me, so official VirtualDub need to be fixed.
This is a bug report, not a request for help.
Maybe VirtualDub can "ignore" WM_CLOSE when it can't be closed, crashing is always a bug.
I would be fine if it would do in this way:
1) If it can easily exit then exit
2) When it cannot easily exit just ignore WM_CLOSE
Posted: Feb 27 2015, 05:27 AM
If you have to kill it dead with fire
TerminateProcess it
ale5000
Posted: Feb 27 2015, 05:44 AM
Well I prefer to "ask to virtualdub" to close, if it can't because is doing something it can reply no and I show a message to the user (to avoid interrupt important things).
It ignore WM_QUERYENDSESSION and WM_ENDSESSION that are messages that Windows send at shutdown to all applications and it is bad.
Apparently works with WM_QUIT.
But I'm not sure if it exit cleanly.
There is a special message to exit from this app safely? Or can it be added?
Posted: Feb 27 2015, 06:07 AM
It could be added as a req
It'd have to do the same steps of tracking down its open dialogs and closing them all
But.....you're still stuffed unless every virtualdub you're updating is already the newest one that does what you want??
Then you're back to closing them all yourself, terminating it, asking the user to do it and waiting until they do or the good old restart your pc to replace the in use file
ale5000
Posted: Feb 27 2015, 06:16 AM
It wouldn't be a problem, I can use the good method with new VirtualDub, and then if it is still opened use the "dirty method" for old VirtualDub.
Maybe can be added a custom message that old VirtualDub simply ignore.
shekh
Posted: Feb 27 2015, 11:34 AM
I think installer terminating a program is something wrong from the user point of view. This is normal only if the program is service with no important state.
The expected and well known way is simply ask the user to close program before installing and upon file copy error.
ale5000
Posted: Feb 27 2015, 08:28 PM
If it doesn't detect it running it won't do anything.
If it detect VirtualDub running it ask to the user if he/she want that setup close it automatically, the user can also say No or close it manually before responding.
If you want to try, it is here: http://forums.virtualdub.org/index.php?act...=ST&f=3&t=23203
12 replies since Feb 26 2015, 01:54 PM Track this topic | Email this topic | Print this topic
